Everything Diesel Discuss R/C Diesel engines here.
PAW 55 Carb Alternative
Reply
Old 04-15-2018, 05:43 PM
sw74gls
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default PAW 55 Carb Alternative
Hi Guys does anyone know a suitable alternative Carb for the PAW 55 the tick over and response on the original wont tick over very well the barrel closes almost fully and the engine still runs almost at a half throttle like tone but burbles and when barrel close a little more it cuts, which I have set to the suggested setting of both holes down at full open barrel?
The outside diameter of the carb insert is 4.72mm a 5mm would be fine I would simply turn it down, any suggestions please? Many thanks Simon.
sw74gls is offline
Old 04-16-2018, 04:01 AM
controlliner
controlliner's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
an Enya .09 carb may work. I haven't measured mine but there may be enough material left after you turn it down to fit. I have one on my PAW 1.49
controlliner is offline
Old 04-16-2018, 04:45 AM
sw74gls
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Paw 55 carb
Really appreciate your help is there anany chance you could measure it ffor me please? Cheers Simon .
sw74gls is offline
Old 04-16-2018, 06:21 AM
controlliner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
When I'm home from work, I measured. If you turn one down, the aluminum will not be solid enough. It will not work
Old 04-16-2018, 12:26 PM
Mr Cox
Mr Cox's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That looks like the carb for the Enya .11 engine?
The Enya .09 carbs have a neck diameter of 7mm, if I remember correctly, and they are a direct drop-in on the PAW .09 engines.
It sounds like the barrel is too lose on the PAW 55, a common problem with the early carb bodies that where made out of aluminium. In the past I have simply remade the carb barrel from Teflon instead, these can have a tighter fit and still slide nicely in carb housing. Here is an example on the PAW .09 engine;
Mr Cox is offline
Old 04-17-2018, 03:48 AM
controlliner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
it is from the Enya Quicky .09 (twin ball race) This carb fits the older .09 from 1968 on up to now. It is a beautiful carb compared to the conventional .09 carb. My CX 11 carb is too big, I think the neck is 9 mm
Old 04-17-2018, 10:37 PM
Hatzdiesel
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default carburettor for small diesels available
Hi Simon ,
there is a aftermarket carburetor available, especially designed for small Diesels
at : scalehobbyshop.de
With its 2,4mm throttle barrel opening diameter it has the right size for the PAW 0,55ccm.
The neck diameter is M5x05mm so you can either late it down to 4.72 mm
or cut M5x0,5mm into the PAW crankcase for installation.
kind regards , Andreas
Hatzdiesel is offline
Old 04-18-2018, 01:28 PM
sw74gls
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Thanks for your help guys.
I would like to express my thanks to you all for your help and advice, many thanks Simon.
sw74gls is offline
Old 09-14-2018, 02:52 AM
stubtoe
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default ENYA AS-05 Carburetor
Hello
I have a PAW 1.49cc /0.09cu'' diesel engine and would like to fit the ENYA AS-05 carb cos the PAW carb for some reason does not throttle ( maybe loose barrel sucking in air !? )
Where can I get hold of one of the AS-05 carbs...joe
stubtoe is offline
