Everything Diesel Discuss R/C Diesel engines here.
Mk 17 prop driver bush removal
Reply
Old 07-08-2018, 04:53 AM
sw74gls
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Mk 17 prop driver bush removal
Hi guys could anyone please advise on how to remove the front prop bushing please?
it has a small collet on the inside between the crank and the bushing, I'm presuming it is a tapered fitting but how would I remove it please ?many thanks Simon.
sw74gls is offline
Old 07-08-2018, 05:31 AM
N99JH
My Feedback: (66)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you have a heat gun, try heating the bushing and than gently pry it with a screw driver. Most collets are made either from brass or aluminum and will therefore expand more than the steel crankshaft.
N99JH is offline
Old 07-08-2018, 05:55 PM
qazimoto
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I save up broken APC props. They have sharp edges. I wedge them behind the prop driver from each side and mount the two prop blades in a vice. Carefully squeeze the vice so that the old prop blades wedge even further into the gap, and gently heat the driver. It should pop off. I usually leave the prop nut (or spinner) on so that the tapered collet doesn't fly off. Prying with a screwdriver could mark the driver and/or the crankcase.
qazimoto is offline
Old 07-08-2018, 09:45 PM
sw74gls
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Thanks for your help guys.
Thanks for your help I'll give it a go , cheers Simon
sw74gls is offline
