Modela 2cc
TX
Modela 2cc
I have a slightly used Modela .12 that runs great
but the contra fits so loosely that when it is cool
it will practically fall down the bore. Funny thing
is that it seals well and has been like this since new.
After the engine is warm it seems to be snug. It
has always hand started easily and so far presents
no problem. I was thinking,(always dangerous) that
this may at some time cause an interesting failure.
Does anyone have an idea on what should be done?
Ralph
Ralph
My Feedback: (19)
RE: Modela 2cc
Do you know what material the contrapiston is made of? It seems that the coefficient of expansion of the contrapiston is greater than the liner causing this problem. The cure would be a tighter fit or a different material.
I have one of those russian 1.5cc (ABC sleeve) with the brass contra in a steel head. It locks up tight a few seconds after it starts not leaving enough time to make adjustments.
TX
RE: Modela 2cc
Yeah Greg ,ABC diesels are hard to set because you have to
be real close when they are started. Once adjusted you pretty
much have to live with it. I wouldn't be a good team racer. No
these Modelas and MVVS are iron and steel. Actually the engine
is a pleasure to adjust,it only concerns me because I have
visions of the contra following the piston at some point and the
embarassing noise that probably would ensue.[:-]
Ralph
Ralph
RE: Modela 2cc
Hello,
I have three of those, none seems to have the problem (only two bench run so far).
Out of curiosity, what prop size/rpm are you getting?
I haven't seen a test of this engine, so I'm a bit hesitant as to what size model to fit it to.
TX
RE: Modela 2cc
I have found that an 8x3 was not enough prop
so went with a MAS 8x4 and get a solid 11.500
rpm with a 3600 idle.That seems to fly 26 oz.
planes pretty good. My latest weighs 25.5 oz.
with 245 sq. inches wing area.
Ralph
Ralph
RE: Modela 2cc
Thank you for these figures. They give me a better idea. I guess they were with the silencer?
About the contra-piston, I don't think it is at all likely to fall during motor run, because there is always positive pressure in the cylinder. The only way would be while turning the motor over by hand.
RE: Modela 2cc
ORIGINAL: gkamysz
Jens Eirik
TX
RE: Modela 2cc
Those figures are with muffler on DDD fuel.
The contra is very easy to move when cold
but firms up nicely when warmsd up and the
screw doesn't try to back out so I'll leave it
be for now.
Ralph
be for now.
Ralph
