Mills Diesel %$#%^&&&&
I have the Indian Mills .75 cc My question is
The cutaway on the piston TOP does it go to the forward or aft position
Thanks heaps fellow diesel flyers
RE: Mills Diesel %$#%^&&&&
ORIGINAL: 123Cat
Thanks Jens
that was my next question
The sleeve orientation????
, you answered it
You need all the power you can get with this motor as there is not a lot on offer
I will check my sleeve orientation now to make sure
Not difficult to place the sleeve : Can you not see the two hole for intake in the sleeve are visible in the treaded hole for carburator in the rear crankcase, turn the sleeve 180 degree. Then you can see the two hole in the sleeve are visible, the sleeve are at right place.
