New 09 Diesel
1 Attachment(s)
The long awaited Parra 09 Diesel/glow is about to be released. Alberto is circulating these pics. It's available in AAC and ABC and upward or downward facing exhaust versions.
It will come with a glow head button even though it's designed as a diesel. It's a screamer not a lugger. Performance: This is from Alberto's email: Today I tested Two wasp and I´m very glad with results. I take only 2 runs of 5 minute each, sufficient time to set the head, and there is the result: - Sea level - 75% humidity - 21 ºC - Fuel; 20 Castor, 35 diethyl Ether, 43 Kerosene, 1,6 DII-3 Every time oil as honey, unburned, head clean with not deposit of burn. PROP Ventury 3,30mm Ventury 2,70 mm Graupner 6x6 17.700 rpm 16.400 rpm Graupner 6x5 19.700 17650 Graupner 6x4 20.910 18.900 APC 6x4 20.600 18.800 NN 6,4x3,76 21.150 19.100 Kavan 6x4 yelow 18.100 Kavan 7x4 black 17.600 16.300 Engine stops and compression never loose. Very easy restart. I test with Parra 2,5 silencer with teflon insert to adapt to exhaust tube and lost only 1.000 rpm and 20db. Also I tested R/C carburetor and Parra muffler version with very impressive idle run. Also I flown a Carbon Trifonov 1/2A combat model and gets time 2.7-2,8 sec/lap with 6x4 graupner and APC. Engines never was forced. http://images.rcuniverse.com/forum/u...40/Om34448.jpg http://images.rcuniverse.com/forum/u...40/Kf14634.jpg http://images.rcuniverse.com/forum/u...40/Rl25258.jpg http://images.rcuniverse.com/forum/u...40/Lw20361.jpg http://images.rcuniverse.com/forum/u...40/Io65145.jpg [img]http://images.rcuniverse.com/forum/upfiles/201440/Be68833.jpg[img] |
RE: New 09 Diesel
Looks great numbers awsome, hope the crank very good grade of steel since it is half cut a way at the intake martin
RE: New 09 Diesel
ORIGINAL: AMB Looks great numbers awsome, hope the crank very good grade of steel since it is half cut a way at the intake martin The manufacturer (in the Ukraine) also makes F2C and F2D engines. Believe me this one will hold together! As anticipated the push/pull Diesel head button is similar to that of the Parra 15, so lends itself to modification for fitting to other engines. My orders in, and it should be delivered with weeks. :D |
RE: New 09 Diesel
Ray,
What's the link for orders & quoted price?? Greg |
RE: New 09 Diesel
ORIGINAL: greggles47 Ray, What's the link for orders & quoted price?? http://www.clubtamaran.com/Parra%201.5%20INFO.htm No final price yet but around Euro 110-125 I'd guess. At Euro80 cents to the Aussie Dollar it'll be a steal! :D |
RE: New 09 Diesel
Parra Wasp 1.5 cc
************************************************** ********************************** Advice received from Alberto Parra 8th July 2012: "I have on stock a few of ABC versions. R/C carburettor available. Discount of 10 euro for advanced reserves. free shipping for two engines. PA15-2 Parra Wasp 1.5 ABC -Special 125 Parra Wasp 1.5 AAC - Special 130 Parra Wasp 1.5 ABC –Special-R/C 135 Parra Wasp 1.5 AAC – Special –R/C 140 Only R/C carburetor 25 Multiwrench 1.5 Wasp 14 BAN-4 Dural combat mount , M3 threaded for Parra Wasp 1.5 12 sÃ*guenos / follow us: http://www.facebook.com/aeromodelismo.tamaran I believe prices are in Euro. |
RE: New 09 Diesel
FIERY believe that is Euros price X .82 (APROX) SHOULD GIVE $$ NOT BAD WRENCH IS EXTRA NOW NOT FREE WITH ENGINE martin
Finish of engine and casting outstanding |
RE: New 09 Diesel
Nice looking engine.
I never could understand why an .09 or 1.5cc class never got off the ground in the USA. This size engine is still my favorite since getting an OK Cub .099 and McCoy .098 in 1951. Some half-A models came out heavy and an .09 makes life a lot easier. |
RE: New 09 Diesel
I think it is pretty neat for a engine. I hope they get it to production soon. It looks great.
The A class competition events are still being run a lot. But at first guys were running Cox Tee Dee .051's in this class as they could use the same plane for 1/2a or A then. But you see the A class event mostly for free flight competition not control line though. It may have been a lack of high performance .09 engines that limited it here in the USA. Many of those high performance .09 engines never made it to the USA. For RC flying, it was the lack of suitable airframes for the .09 engines that limited it a lot. |
RE: New 09 Diesel
These engines are specifically aimed at the popular European and Anglo-sphere 1/2A Combat and Team Racing c/l market.
More pictures and details this morning. http://www.clubtamaran.com/waspRC.JPG http://www.clubtamaran.com/Parra%201.5%20INFO.htm This is a nice touch! http://www.clubtamaran.com/drawn-wasp1.JPG |
RE: New 09 Diesel
The engine is nicely finished and figures are impressive. The crankshaft looks the goods.
Unfortunately only "combat" exhaust ABC models are currently available. I am waiting on news of "racing" spec exhaust (usual side) engines coming into stock. The photograph above shows an ENYA R/C carb which will be fitted where the R/C spec unit is ordered. Interesting, the "MK-17" style tommy bar compression adjuster shown in the blueprint schematic drawing was dropped for the more sophisticated "push~pull" vernier. |
RE: New 09 Diesel
1 Attachment(s)
AMA Class "A" never favored the .09 engine displacement. For maximum power such as control line speed the .19 was top dog, first the McCoy redheads and then the K&B greenhead blew everyone away.
When the USA joined the .15 FAI competitions the K&B greenhead went right to the top of the list. Bill Atwood saw the advantage of using an .051 engine in a half-A FF model he made his .049 and .051 engines which Holland Hornet copied and they also went the .049 - .051 route. Bill Atwood developed the TD engines for Cox so they offered both the .049 and .051 sizes too. While the K&B Greenhead .15 and .19 engines were proven winners the Greenhead .09 actually put out more power per displacement than either of it's larger brothers but the .09 had no place to go. K&B announced their Greenhead .09 around 1954 and I ordered one from my local dealer but as far as I know they never made them until around 1957. When they did come out they were a real winner. Early .09 greenheads had a long, open exhaust port and would sometimes become warped. K&B quickly modified the design by adding a web in the center of the exhaust port to strengthen it. |
RE: New 09 Diesel
ORIGINAL: fiery The engine is nicely finished and figures are impressive. The crankshaft looks the goods. Unfortunately only ''combat'' exhaust ABC models are currently available. I am waiting on news of ''racing'' spec exhaust (usual side) engines coming into stock. The photograph above shows an ENYA R/C carb will be fitted where the R/C spec unit is ordered. For racing I'd be inclined to cut the exhaust stack off altogether. It'd make it much easier to put into a cowl. The small Enya 09 r/c throttle seems about the only game in town for a 1.5cc diesel. I have an original Oliver Tiger Cub 1.5cc diesel fitted with one from the factory. :D |
RE: New 09 Diesel
I just read this enail from Alberto about the Wasp 1.5cc engines:
I have sold almost all units of first engines sent me. I have now some units of "C" version of diesel and two glow. please, see more details about. http://www.clubtamaran.com/Parra.htm regards Alberto |
RE: New 09 Diesel
I am on the reserve list, but will have to wait for more to come in to get a 'racing' version.
My lovely girlfriend got me a Parra 2.5 R/C Limited Edition for Christmas this year, and he's lonely. |
RE: New 09 Diesel
After some 55 years the TD 09, a 1.5cc engine, is still the standard of comparison. As said the 09 size engines were orphans in the USA, not really paid attention to. I think the TD 09 would have been a good free flight engine, but I've only seen one or two at contests. There was some thought at one time that the FAI was going to go from 2.5cc to 1.5cc for free flight. The Johnson Bulldog 09 was designed to offer another American 1.5cc engine, but the change did not occur.
RE: New 09 Diesel
The Australian Sesqui 1.5 was also developed-in diesel and glow versions about a decade after the Johnson Bulldog, (Dan Vincent probably has one!....)-also in the expectation that the FAI was going to approve an imminent change from .15 to .09 for International competition. As we know this didn't happen second time around either-which is why not a lot of Sesquis got made.......and why they command big prices. The FAI did go as far as loosening the F1C class rules to allow the use of smaller engines in smaller sized models-called F1C(Mod)-but this never caught on (I was one of the few to try it)-this would have been around 1985/86. Then they jumped in boots and all with the F1J class and a 1cc limit-but this is now dropping in popularity.........(the need for US $200+ engines might have something to do with the decline in F1J)
ChrisM 'ffkiwi' |
RE: New 09 Diesel
1 Attachment(s)
I do have the Std and RC versions of the Johnson Bulldog. I wanted a Sesqui for a long time but the closest I got was seeing one that Stu Richmond had when he lived near me in Apopka, FL.
The Sesqui was gorgeous but I never did understand why the Intake was right in the exhast port blast. |
RE: New 09 Diesel
I toyed with the idea of putting down a deposit on a Sesqui, (it was like the original Doonside Mills project you had to put up an initial deposit and become 'subscribed' to get one-then pay the balance when they were completed) but I was at university at the time and they were expensive even then-and with the amount of flying I was doing at the time I couldn't justify the expenditure. Wish now I had............... Quite a number of them subsequently formed the basis for various 1/2A T/R specials in the hands of a few skilled people. I don't know how many were actually produced. Peter Burford probably does. IIRC the intent was to offer a Mk1 a Mk2 and a glow version
ChrisM 'ffkiwi' |
RE: New 09 Diesel
ORIGINAL: Jim Thomerson After some 55 years the TD 09, a 1.5cc engine, is still the standard of comparison. As said the 09 size engines were orphans in the USA, not really paid attention to. I think the TD 09 would have been a good free flight engine, but I've only seen one or two at contests. There was some thought at one time that the FAI was going to go from 2.5cc to 1.5cc for free flight. The Johnson Bulldog 09 was designed to offer another American 1.5cc engine, but the change did not occur. to 450 sq"s. The entire model minus fuel weighed 12 ozs. I won a lot of class A FF contests with that model; I even briefly set the Class A national record during a Flyoff with Ron Young and his 600 Texan. Then Ron beat my time on his last flight, 10 minutes after I posted my time. Lee Hines' Ramrod 250 was a correction to Ron St Jeans Ramrod 250 version, because St Jean made a mistake in scaling down to 250s" size. This mistake was never corrected in the magazine or kit version. I'm guessing this was around 1966. So, like the MVVS, the Cox TD had similar qualities, both are light and both put out excellent power(for the time). Tony |
RE: New 09 Diesel
There's something about the TD .09 that is just .... honest. Hard to put a finger on it.
But Dayyamn are they loud. |
RE: New 09 Diesel
Loud, I always thought the old Arden .09 was very noisy.
RE: New 09 Diesel
1 Attachment(s)
I would like to see a peformance and weight comparison between the PARRA Wasp 1.5 cc ABC diesel and the FORA 1.5 cc ABC diesel
http://www.hobbyclub.com/product_inf...oducts_id=1062 |
RE: New 09 Diesel
I expect they would be pretty close, but not having the ability to put a muffler on the Fora makes it worthless to me where I live.
RE: New 09 Diesel
I would hope the Fora is better. The numbers posted earlier were about the same as my AP .09 and LA .10 on glow with no muffler using the 7"-4p. I am still looking for an excuse to try a diesel again.
