RE: mpjet 061D
Are they in production or not? , perhaps one our buds in Europe Mr Cox or the chap in Germany could call them and get the status , right now a mystery martin
RE: mpjet 061D
1 Attachment(s)
OK GUYS Time to clear up the mystery called I Care RC the MPJET 061 D is still in production
Issue with exhaust extension screws you need one 3mm x30mm length and 3mm x40mm length they packed 2 3mmx30 in the package it is too short for they rear muffler screw can only get about 2 turns, not enough. I picked up 3x40mm at the LHS today and issue solved get a full grab. These are allen cap screws was not thinking should have picked up some 30mm long also minor issue you need a flat blade screwdriver on one ( the original) and an allen on the other 40mmm length will change out for allen 30mmm length thus only one tool needed martin the allen head is 40mm long |
RE: mpjet 061D
Well Guys I was WRONG WRONG WRONG the spacer is anodized black aluminum NOT PLASTIC rerun today and quite a oil leak at edge so took a file and had to take a very tiny bit of the top lip
top lip to arc out for perfect it and guess what after first hit with file shiny aluminum that will keep her dry now martin If not a tiny bit of Coppercoat on the edges Oh took the temp too 152F pretty cool |
RE: mpjet 061D
A while back, I ordered a 2nd MP Jet Classic diesel from David Owen, down under. He said something about MP Jet making the engines in batches, at random times and you never know which batch will be the last ever.
RE: mpjet 061D
MP JET has the molds and dies may be some time before an other run but do believe it will happen, So when some run off David Owen will have them. get on his list
this has occured before the MVVS 15 is an example regards martin Post note just called I Care RC Canada, they are waiting for the MP Jet 061D RC , they have the venturi one in stock, spinner nuts in stock, also waiting on exhaust extension they have on order so they will be made and shipped |
RE: mpjet 061D
spinner nuts for PM Jet 061 diesel SUCCESS have 3 on the way from I care RC Quebec no exhaust extensions yet they expect them in this week or next martin
