back to c/l diesel
1 Attachment(s)
Ok group after a month my Sig shoestring finally made it box reads 10-15 size engine it will get the sharma 15 before we risk the Taipan twin BB66, have not flown c/l in decades
will play it safe martin |
RE: back to c/l diesel
Martin,
The shoestring is a good flier. The Sharma will be a good match for it to begin. Use an 8X5 or 8X6 prop and short fill the tank until the return dizzys abate. about 50' lines will be about right - should give you about 3-3.5 second laps. Good luck mate. Greg |
1 Attachment(s)
I inherited this "Try-Sickle" stunter along with a whole bunch of C/L goodies including handles, lines, and engines, which due to their being the 'other' form of iginition I will not show. The shade of green of the "Try-Sickle" [:-] is 'interesting'.
It needs a landing gear repair. I will convert it to standard tail dragger configuration, with composite legs bolted to the fuselage, and repair the broken rudder. Apart from these issues it is sound though the venerable Fox .35 it came with is missing a NVA. I have a spare ST style NVA NIP that I am told fits right up. I will probably re-power it with a .29 ~.35 size diesel anyway, as befits a discerning returning C/L flyer. My old PAW .35 needs to stetch it's legs. I am sure Mr Owen can supply a venturi for it. Or, I could run the 'most appropriate' command economy 5 cc Kometa (ST G21/29 copy) I have. Mecoa/RJL do a Kavan Muffler and adaptor for the ST G21 which i am sure will fit up perfectly. I also have also received a battered "All American". It is a .30 size old style stunt ship with an ancient offset plug OS bolted to it. It is complete, but will need a complete strip down, and recover. The flaps on it seem to be no longer actuating. Do C/L chaps still use cloth strip hinges these days? |
Looks like the biggest ( at least longest chore) is sanding the big slab of a wing to correct profile, off subject but did pick up the NIB OS FP 10 today that I got on flea bay, being the chap only lives a few miles away met him and picked up, he liked that , no pack and mail hassle and had it in a half hour not days
good day a plane and engine all in about an hour martin |
How did the holes in the wing, shape of the gear get there, do not think retracts?? nice project however guess the engine is a Ruskie martin
Martin,
I'm sure volumes have been written about sanding wing sections and all that, but in the end I'm not so sure it matters very much at all. My recommendation - if you are going to bother with a section at all - is a symmetrical section with the high point at about 35%. This will help stop it wanting to climb into the wind. With the wing area it has you certainly don't need a flat bottomed section. Some people also have a lot of success with a 2/3 - 1/3 section. Next point use some 1/8" sq spruce as a trailing edge and only shape down to the 1/8. That'll reduce the amount of shaping you need to do and give a stronger wing. The rub of course is the wing is very thin and not easy to sand to a completely accurate section. Fiery, Yes - some do use cloth hinges, but plastic RC hinges are much more common. The cloth to use is the old fashioned cloth tape from the haberdashery (do they still exist??). Glue the tape with C23 Balsa glue. And boy that is an UGLY big sucker! Good luck to you both. Greg |
GREG Great tip on the 1/8 spruce trailing edge, THX thats a will do-martin
think we can find some cloth for hinge a piece of old bedsheet may do the trick?? they include a strip of thin plastic material looks like clear mylar not the usual stuff you glue in with CA |
1 Attachment(s)
Martin
They are the (in)famous "Irish Retracts" . The retract wells are just painted in black enamel on the covering. The ruined undercarriage mains and nose wheel will all be removed, and the covering re-instated. I won't try too hard to match that nausea inducing colour :). For cloth strip hingeing, I have looked at the contents of the waxing kits my lady friend buys to attend her grooming requirements (no tasteless comments please gents!). The cloth strips included would be perfect. Thin, flexible and very strong. |
I also have some hard plastic pinned hinges martin
Pinned hinges are a better option than mylar, I recall C/L hinges need to be as flexible as possible. I am sure the experts here can advise.
Hi Fiery, that green thing looks like it might be a bit of fun. I'd have reservations about using a PAW 35 on a slender profile fuselage like that, though, and it will weigh a fair bit more than the Fox. Maybe a good 19TBR instead?
ORIGINAL: fiery Martin They are the (in)famous ''Irish Retracts'' . ChrisM 'ffkiwi' |
ORIGINAL: AMB I also have some hard plastic pinned hinges martin Glue with Formula 560 or epoxy - but be careful where the epoxy gets. I've managed to glue them up and they quickly became exhinges. :( |
ORIGINAL: greggles47 Martin, I'm sure volumes have been written about sanding wing sections and all that, but in the end I'm not so sure it matters very much at all. My recommendation - if you are going to bother with a section at all - is a symmetrical section with the high point at about 35%. This will help stop it wanting to climb into the wind. With the wing area it has you certainly don't need a flat bottomed section. Some people also have a lot of success with a 2/3 - 1/3 section. Next point use some 1/8" sq spruce as a trailing edge and only shape down to the 1/8. That'll reduce the amount of shaping you need to do and give a stronger wing. The rub of course is the wing is very thin and not easy to sand to a completely accurate section. Fiery, Yes - some do use cloth hinges, but plastic RC hinges are much more common. The cloth to use is the old fashioned cloth tape from the haberdashery (do they still exist??). Glue the tape with C23 Balsa glue. And boy that is an UGLY big sucker! Good luck to you both. Greg |
A few years back I did do cloth hinges, I used strips maybe 3/4 inch wide glue on top of stab, bring under and glue on bottom of elevator, then used a 2nd one next to it
that was glued to bottom of stab then up and over and glued to top of elevator , one pair on right and left side of elevator, worked well no slitting of wood and very flexible of course martin |
ORIGINAL: fiery I inherited this "Try-Sickle" stunter along with a whole bunch of C/L goodies including handles, lines, and engines, which due to their being the 'other' form of iginition I will not show. The shade of green of the "Try-Sickle" [:-] is 'interesting'. It needs a landing gear repair. I will convert it to standard tail dragger configuration, with composite legs bolted to the fuselage, and repair the broken rudder. Apart from these issues it is sound though the venerable Fox .35 it came with is missing a NVA. I have a spare ST style NVA NIP that I am told fits right up. I will probably re-power it with a .29 ~.35 size diesel anyway, as befits a discerning returning C/L flyer. My old PAW .35 needs to stetch it's legs. I am sure Mr Owen can supply a venturi for it. Or, I could run the 'most appropriate' command economy 5 cc Kometa (ST G21/29 copy) I have. Mecoa/RJL do a Kavan Muffler and adaptor for the ST G21 which i am sure will fit up perfectly. This of course is assuming that it flies well in the first place with the less powerful Fox. Good luck! |
The "peanut gallery" at my local club await my display of fly-by-wire finesse with bated breath ...
There is back-up. I will have an old C/L flyer by my side to take over if vertigo sets in. For my first flights (I am an optimist using the plural) I will adopt the time honoured practice of "stiff arm" control. |
Derek, I hope that you and Martin are aware that you can use monokote or almost any film as a hinge also
www.builtrightflyright.com That takes you to a complete tutorial on how to do it at walts site. Just be aware that it takes a little more effort then R/C flyers usually like to expend on a model, but the results are striking and you have no gap in your surfaces. You can also use dacron or polyester fabric and they will last forever. dennis |
1 Attachment(s)
Received this from Walter just recently Dennis. Also a little Goldberg designed ab initio stunt trainer, the Black Hawk Models rendition of the "Glo-Bee" from 1947. Elevator looks a little large!
I'd have to say the "Comedian" is just about the best 'traditional' kit I have ever had the pleasure to come by. So how is the "Sakitume" going? Probably not flown yet. Needs a diesel though ;). A diesel head equipped .40 FP would be perfect :D |
I use sewn figure 8 hinges made of dental floss. Cheap, easy, and never wear out.
1 Attachment(s)
ORIGINAL: fiery Received this from Walter just recently Dennis. I'd have to say this is just about the best 'traditional' kit I have ever had the pleasure to come by. So how is the ''Sakitume'' going? Probably not flown yet. Needs a diesel though ;). An RJL diesel head equipped .40 FP would be perfect :D |
1 Attachment(s)
I built a kit Shoestring from the kit as a diesel Goodyear racer about 4-5 years ago. I modified it quite a bit to make it stiffer and to increase it's ruggedness.
It still flies beautifully after only one major rebuild after a prang where the pilot (Greg) had to crash it because of the Nelson diesel going "hard" in flight with the cutout not working. http://images.rcuniverse.com/forum/u...40/Ay74871.jpg There's quite a few modifications from the standard model. http://images.rcuniverse.com/forum/u...40/Fa86036.jpg The most obvious is the 1/4" square Spruce leading edge and the 1/20" hardwood trailing edge. A symmetrical airfoil was carefully sanded in with a high point at 30% of root to tip wing chord. The Tailplane has a core of 1/64" ply, and the fin is three laminations of the same. Wing, tailplane and fin are all covered in vacuum bagged 3/4 ounce epoxy coated fibre glass. I always stitch the team racer hinges with Rayon fibre. Ray |
1 Attachment(s)
I've found some more construction pics.
In order to stiffen and strengthen the fuse I inserted a 1/2" x 1/4" length of spruce. The model was built for an R250 originally, then got a Nelson 15D and finally a Parra 15 Diesel. http://images.rcuniverse.com/forum/u...40/Xv64125.jpg Once the glue dried, the engine bearers supplied were discarded and a longer set were fitted that extended right back to the wing max thickness position at about 30% root chord. http://images.rcuniverse.com/forum/u...40/Mh20672.jpg Two 1/64" ply doublers were fitted to the fuselage front end one at a time so the slot for the wing could be transferred accurately. The doublers extend well back from the wing trailing edge region to strengthen a problem area for Goodyear Racers. The engine mounting plate is from 2024 Alloy and is made for R250's. http://images.rcuniverse.com/forum/u...40/Di10107.jpg Pic shows LE and TE being fitted. I normally use C23 glue (like Ambroid) for joining the wing bits, PVA for the LE and CA for the TE. http://images.rcuniverse.com/forum/u...40/Zk67128.jpg The lot gassing off for a few days. Not shown is the brass tube and slot in the fuse for a plug in mono-wheel u/c leg. Unlike US Goodyear we can use single wheel/leg undercarriages. http://images.rcuniverse.com/forum/u...40/Du20518.jpg |
That was a beautiful flying model Ray, I was sad to have to ditch it, but I'd rather a crashed model than a burnt out motor any day.
Greg |
ORIGINAL: greggles47 That was a beautiful flying model Ray, I was sad to have to ditch it, but I'd rather a crashed model than a burnt out motor any day. Greg there's another kit still in it's shrink wrap down the shed. :D |
GREGGLES the pix are great this will really help when I get working on mine as a stock build it leaves a little to be desired . great mods and really needed martin
What flying weight did it come in at Ray?<div>
</div><div>For the record Ray and Greg</div><div>My Swee Pea turned out to be a heap of excrement. Not only was it too heavy at 600gms flying weight.</div><div>I ended up flying it with my Blue Head MVVS making the model nose heavy after ballancing just right with the CS Olly.</div><div>The day was too windy and model slammed into the deck after 6 laps.</div><div>I suspect the V tail wasn't lined up correctly either.</div><div>Back to the drawing board. No, I'm not normal, still going to do things different.</div><div>Looking at building one of the current IF1 Wilson wing Cassutts.</div><div> </div><div>Fredo</div> |
1 Attachment(s)
ORIGINAL: PWF63 What flying weight did it come in at Ray?<div> </div><div>For the record Ray and Greg</div><div>My Swee Pea turned out to be a heap of excrement. Not only was it too heavy at 600gms flying weight.</div><div>I ended up flying it with my Blue Head MVVS making the model nose heavy after ballancing just right with the CS Olly.</div><div>The day was too windy and model slammed into the deck after 6 laps.</div><div>I suspect the V tail wasn't lined up correctly either.</div><div>Back to the drawing board. No, I'm not normal, still going to do things different.</div><div>Looking at building one of the current IF1 Wilson wing Cassutts.</div><div> </div><div>Fredo</div> I built a Sweet-pea as well also with disappointing results. It was very unstable in the Kuringai wind, perhaps a consequence of the Vee type tail as well.. The Shoestring and the Ohm Special are two reliable model designs. There's a few Ohms with the MVVS in the Mannering Point club that fly well. I can supply scans if you want. http://images.rcuniverse.com/forum/u...40/Ig13639.jpg Ray |
Gazimoto first V tail I am aware of, the elevator only using half of it to me seems odd, in up mode seems looks it would have an aileron effect and cause the the plane to slacken the lines, just my theory, maybe no adverse effect martin
airflow direction not the same (equal) on both sides |
ORIGINAL: AMB Gazimoto first V tail I am aware of, the elevator only using half of it to me seems odd, in up mode seems looks it would have an aileron effect and cause the the plane to slacken the lines, just my theory, maybe no adverse effect martin airflow direction not the same (equal) on both sides the half elevator idea is quite common with control line racers, but they're usually on the "outside" of the model. This Vee-tail has a dihedral angle of just 20 degrees, much less than with an r/c model so it should be ok. Takeoffs had good line tension it just couldn't cope with the gusty wind at our favorite flying site. It's located on a ridge overlooking the Pacific Ocean and surrounded by tall trees, so it's more exposed than normal. Ray |
1 Attachment(s)
Here's Swee Pea with CS Oliver still on the bench. No need to see after photos....lol
We'll just remember this one. |
ORIGINAL: PWF63 >Looking at building one of the current IF1 Wilson wing Cassutts.</div><div> </div><div>Fredo</div> My first GY model was a Cassutt (Plum Crazy). Nother nice flier. Can you please explain IF1? I haven't heard that. Greg |
ORIGINAL: greggles47 ORIGINAL: PWF63 >Looking at building one of the current IF1 Wilson wing Cassutts.<div></div><div>Fredo</div> My first GY model was a Cassutt (Plum Crazy). Nother nice flier. Can you please explain IF1? I haven't heard that. Greg International Formula One Sorry mate, I've had my head stuck in the IF1 and Cassutt owners forums as well as the Reno web sites for too long. Trying to research the modern modified Cassutts that have raced at Reno the last 10 years. Some of the jargon has stuck. Fred<br type="_moz" /> |
