Hi
Hi Dave pretty quiet on th site lately martin
RE: Hi
Yes sir, too quiet, too hot to do much here, even too hot to ride the Harley.
RE: Hi
You should have been over here last week. All big flywheel farming diesel stuff blocking regular road traffic. ^)
Thump-thump-thump-shuga-thumb-shuga-thumb-thumb |
RE: Hi
Pe a few years back I did a fast 10Knts max with my Budda in a surplus naval launch and then again in my 23ft North sea skiff with a 2 cyl Bukh diesel ( at least not blocking roads)
and thats sort of what it sounded like martin I had a few last laughs though when a few folks sort of pointed and made a few jokes as they roared by in their high speed boats and a few miles down the river ran out of gas and I towed them in chuga chuga bang chuga Back to biz if the temp drops want to get in a flight on my Nuevo 1300 electric conversion with the TT10 davis conversion this week maiden flight |
RE: Hi
RE: Hi
Nice just needs the ring thing like PAW then will sound like a ***** cat not a screaming tiger martin
Did not think the ***** would be an issue ok purring kitten |
RE: Hi
1 Attachment(s)
Manufacturer: John Deere
Fuel: diesel Aspiration: natural Cylinders: 2 Valves: 4 Bore/Stroke: 6.125x8.00 inches [156 x 203 mm] Displacement: 470.7 ci [7.7 L] Cooling: liquid Coolant: 35 qts [33.1 L] Compression: 16:1 Rated RPMs: 1125 Firing order: 1-2 Starter type: V4 gasoline pony motor Maybe one of these was in the parade. Francis Person gets credit for this discovery, I thought the JD R had the biggest engine but it is a mere 416 cu in. BTW, that pony engine has more HP than most other tractors. |
RE: Hi
Dave 235C.I per cylinder thats more than a few 4 cylinder cars martin
RE: Hi
ORIGINAL: gkamysz I ran this last week. It was louder than I could handle. http://www.youtube.com/watch?v=3x-MYdpmmoo Sounds great! |
RE: Hi
ETA 15 Mk III ... mmmmm ;)
Still drooling here downunder Greg. The ringing ears afterwards - worth it. EDIT: I think we can take a cue from the gl*w forum. Why not a "Club PAW" "Club ETA" "Club Oliver" etc? Or, is there not enough interest / activity on this forum? It would be good to share experiences with fellow enthusiasts of a marque. Might stimulate some nore posts on this forum as well. Thoughts? |
RE: Hi
ORIGINAL: gkamysz I ran this last week. It was louder than I could handle. http://www.youtube.com/watch?v=3x-MYdpmmoo Really nice engine with very good quality of hand work by Ken Bedford. |
RE: Hi
ORIGINAL: Hobbsy Manufacturer: John Deere Fuel: diesel Aspiration: natural Cylinders: 2 Valves: 4 Bore/Stroke: 6.125x8.00 inches [156 x 203 mm] Displacement: 470.7 ci [7.7 L] Cooling: liquid Coolant: 35 qts [33.1 L] Compression: 16:1 Rated RPMs: 1125 Firing order: 1-2 Starter type: V4 gasoline pony motor Maybe one of these was in the parade. Francis Person gets credit for this discovery, I thought the JD R had the biggest engine but it is a mere 416 cu in. BTW, that pony engine has more HP than most other tractors. |
RE: Hi
Greg,
In the end you were too lean, and over compressed if my ears still serve me well. (they did suffer though;) ) |
RE: Hi
Pe, Yes watching the video it probably was. It long enough to get hot. It's so loud that I could barely think. I only ran it for 30 seconds prior to making the video so I'm not very familiar with it. I put it back in the box to await a location where my neighbors won't be wondering what it happening so I can run it for a while. My ears must be getting more sensitive, as it was just too loud to bear. I wonder if I can make out the compression settings through ear defenders? A couple years back I ran a TD.049 with a pair on and it was OK.
I've drooled over one of these for years, the Elite really, but I refuse to pay the going rate. This one came along at a reasonable price and I couldn't pass it up. I was elated when it felt perfect after a few drops of fresh fuel. I also got a Taifun Orkan (turned out to be new) and Taifun Zyklon at the same time. Greg |
RE: Hi
Ear defenders work quite well. They are designed not to alter the sound character too much. I wish we had them when I was young. Now I am turbine deaf (around 6000 Hz)
RE: Hi
ORIGINAL: gkamysz Pe, Yes watching the video it probably was. It long enough to get hot. It's so loud that I could barely think. I only ran it for 30 seconds prior to making the video so I'm not very familiar with it. I put it back in the box to await a location where my neighbors won't be wondering what it happening so I can run it for a while. My ears must be getting more sensitive, as it was just too loud to bear. I wonder if I can make out the compression settings through ear defenders? A couple years back I ran a TD.049 with a pair on and it was OK. Greg The lower exhaust note of my new diesels is much easier on my ears than the glow motors I have. With the TD. 010 it's always a hurry to set the needle and commit aviation, the PAW and Schlosser I can run in my hands all day. |
RE: Hi
Devious Dave one of my quietest one is the Kand B 20 sportster Davis head stock muffler,<that I picked up from Bob
The nice thing about diesel the combustion process is over by the time the piston is at the bottom of the stroke unlike glow its still burning with glow very visible at night with no muffler, you just do not have that high pitched noise at least at the RPMs I run 11K or less martin |
RE: Hi
I will have to post a video on youtube of this John Deere 820s under load
Thanks Francis |
RE: Hi
ORIGINAL: AMB glow its still burning with glow very visible at night with no muffler I don't think that pure methanol shows any flame when it burns. |
RE: Hi
I've seen white flame come from cox engines in the dark.
