Go Back  RCU Forums > RC Helicopters > Exceed RC Support - Helicopter
Reload this Page >
zero throttle but blades are still spinning...
Exceed RC Support - Helicopter Discuss all Helicopter Support for items purchased or will be purchasing at Exceed RC.
Old 03-29-2008, 04:21 PM
rftusa2008
Default zero throttle but blades are still spinning...
Trim #2 is way down already. Turning trim # 2 up will increas the speed at zero throttle. Can anyone let me know what's wrong. On the transmitter that came with the heli, the throttle zero setting is resting between 1st and 2nd notch level. It cannot go down any further. Thanks for any help.
Old 04-02-2008, 05:44 PM
yadac123
Default RE: zero throttle but blades are still spinning...
sorry I don't understand your question. what's your heli?
Andy
Old 01-23-2013, 09:51 AM
charlie61
same issue falcon40v2 2.4 . as soon as i plug the battery in main blade starts spinning. tx iis set to zero throttle. yes i did have a crash an snaped a main blade. should i change the motor(esc is mounted on the motor)  or would it be in my receiver. thanks
