Update on Re-arange Battery and Receiver
For those interested, if you move the RX for the Eagle 50 under the frame, make sure you put it on its side if thats the way it was from the factory. It aperantly has a small gyro in it. I put mine on its side and when it would lift off it would rotate 180 degrees before stableizing. After puting it on its side it worked great.
