help... new raptor g2
when i try to power up the tail blade spins but the main blades spin really slow.. causing it to spin out of control. i tried powering it up before and it spun fine. what can it be. im new to rc and im in new york city and i dunno how popular rc helis are here. im also not too familiar with the controller.. so any info would help. thanx [&:][&:]
HI
RE: help... new raptor g2
what are the default settings for the dip switches?.. i have the pcm wk0701.. and is it normal for heli to slide ALOT to the left, like fast.. with corrective stick inputs hover is very difficult when the slide needs alot of correction... sorry learner here..
Thanx
Thanx
MD
Yes. Well not tons but you can easily flip over to the left. It is a natural tendancy
for the helicopter to go left. It is something you learn to compensate for.
Make sure swashplate is level... your trim tabs are adjusted correctly
Maybe these links will help you. Applies to almost all electric heli's
Setup tutorial 1 http://www.youtube.com/watch?v=dFMYaIjqIWg
Setup tutorial 2 http://www.youtube.com/watch?v=DeAmsecIbPo
Trimming and Maintenance http://www.youtube.com/watch?v=oLP_jGEmkn4
And maybe RADD's school of flight
http://www.dream-models.com/eco/flying-index.html
HI
when I spin up and need to compensate for the heli rotating left by trying to give right rudder NO reposnse. I hear movement and see slight movement in the tail but no right rotation.. after every initialization I check that I get the correct responses. The tail and slider is centered without throttle.. only when I give it throttle and want or need to rotate right there's no response... I wish there's a troubleshoot guide somewhere to learn....
thanx
thanx
AB, CANADA
He means is the gear on the servo worn down to the point it doesn't grab and even if it is a bit it can still spin and not do anything every once in awhile. You can take the top off the servo to look.
HI
heres a dumb question but i need to ask.. for spare batteries. I'm looking at one with JST plugs.. in the picture looks rectangular. my stock speed controller has circular plugs.. do I need this [link=http://www.hooobby.com/battery-jst-adapter.html]battery adapter[/link]
for it to connect without replacing my speed controller????
the plug on the raptor g2 esc is banana plug and JST is something else. If you don't want to change connectors you can get a spare battery 1300mah from xheli.com and that already has banana plug
Andy
Andy
ORIGINAL: jinxd
Thanx
Thanx
1. off
2. on
3. off
4. on
5. off
6. on
7. off
8. off
9. on
10. off pitch (need to turn on to adj the pitch setting NOTE: 11 and 12 off) v1 12 oclock v2 100%
11. i forgot the 11.
12. gyro sens/ rudder mix (need to turn on to adj sens NOTE 10 and 11 off v1 0 turn all the way to left, v2 75%. or 3 oclock
