dip switch settings
RE: dip switch settings
ORIGINAL: zourious
can any 1 tell me what the dip switch's are supposed to be set at?my son set them all to off
1. off
2.on
3.off
4.on
5.off
6.on
7.off
8.off
9.on
10.off/ if on need 11, 12 off
11.off/ if on need 10, 12 off
12.off/ if on need 10, 11 off
i have set all the dip switch's to the right spot and it still wont lift off.i unpluged the motor and checked the pitch slider to see if my pitch was off and the slider was right in the middle.what other setps should i take now to narrow down the problem and fix it.it was flying perfect befor my son turned the switch's off.do i have to reprogram the radio and is there a cirtain way to do it?
also it is the raptor g2 v2 dont know if they used a diff radio with the v1 g2
if you can not get it lift off your pitch is off. put dip switch 10 to ON and adjust the pitch.
Your pitch slider needs to move up so you get a positive pitch
Andy
Andy
i have used the manual to setup the pitch and it still wont lift off.it almost like something reversed cause at full throttle it has negitive lift and when you let off the throttle quite quick it will start to lift off...???.is there anyway that the motor qot reversed.mine spins up clock ways.also the blades are supposed to be thin side going with clock ways or thick part?cause my blades the thick part is going with the clock ways spin.
thanks for the time yadac123
i have got it figured out thanks alot for the help guys..it was #6 is supposed to be off.now to figure out what ball link to adjust to stop it from going right.i ahve the trim all the way left and it still goes right.is it the long 1 or the short ball link?
also i wanna buy the cnc upgrade's for it and i have found a site that has the full rotor head and tail assemably for the walkera 36.i have heard i can use these parts is it true?just wanna make sure befor i order anything ...
