Exceed RC Support - Helicopter Discuss all Helicopter Support for items purchased or will be purchasing at Exceed RC.
Raptor G2...Time to rebuild and upgrade
Reply
Old 05-07-2008, 11:50 AM
rftusa2008
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Raptor G2...Time to rebuild and upgrade
My Raptor G2 is currently in pieces. I have walkera 36 tail and main rotor metal assembly. I have a DX7 transmitter and will install a Specktrum receiver. I'm planning to upgrade the servos and gyro. Any recommendations?. I don't even know what size the servos are. I have Trex 450 and I know the Trex servos don't fit in the G2. I am still new to this hobby but managed to build 2 450s. I'm confident I can put this together with the right parts....my fingers are crossed!
Thanks in advance.
rftusa2008 is offline
Old 05-07-2008, 09:49 PM
huey1639
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Raptor G2...Time to rebuild and upgrade
Goto raidentech.com or xheli.com. Both sites have the upgrade parts for the raptor g2. Youll be able to see what size you can use then my choice would be futiba. Im in the process of upgrading one of my raptor g2's myself
huey1639 is offline
Old 05-09-2008, 05:19 PM
rftusa2008
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Did you replace your cyclic servos? Here is a pix of my raptor g2 with walkera 36 aluminum rotor head and tail.
ID:	946262   Click image for larger version
Old 05-11-2008, 07:37 PM
yadac123
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think you should keep your cyclic servo stock and upgrade the tail to digital. Which gyro you will be using? GY401?
Andy
yadac123 is offline
Old 05-12-2008, 03:27 PM
rftusa2008
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have 2 GY401s that works well for my 450's. I was thinking using the same. I just don't know about the tail servo. I have HS9650mg on the 450's. For the motor i was thinking of getting the 25am Exceed ESC and Exceed motor. Fairly cheap from xheli. They are 50 something for both. I don't know if xheli still have the g2 upgrade deal for ESC/motor/battery for 79 bucks.
Old 05-12-2008, 03:35 PM
rftusa2008
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
assembling the frame/body/tail is fairly easy. finding zero pitch and getting the +11/-11 would be hard I think since I have not seen a build video yet. let me know what problems you encounter if you happen to build yours first. i'm putting together the electronics that I need to finish mine. i'm not in a hurry since i have 2 450's to play around with.
fyi - I put together the links based on the walkera instruction manual. It has the proper link size in the last page. May or maynot need minor adjustments for zero pitch.
Old 05-12-2008, 04:06 PM
yadac123
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think for a beginner who wants to get into 3D you should try -10 and +10 first.
http://www.xheli.com/brushless-motor...o-battery.html you should get this one and it work for exceed g2.
Andy
yadac123 is offline
Old 05-12-2008, 04:07 PM
yadac123
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
As for tail servo you should get a digital because the GY401 works best with digital servo.
Andy
ORIGINAL: rftusa2008
yadac123 is offline
Old 05-12-2008, 06:29 PM
rftusa2008
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks yadac123. is the swash type of the G2, 90 or 120 degrees? i don't know the difference. my 450s are 120 degree swash type. i'm using the 450s as a model for rebuilding the G2. I have the diagram downloaded from walkera site for the 36 and Bob Finless video for reference but wasn't sure about the swash type. I'll be getting the 401 and 9650 combo for the g2. it's pricey but i know it works. If i decide to buy a different cyclic servos, what is the size of the servos? I will crash this a lot so I want one that is durable. The stock servos, two of them are stripped from a minor crash.
Old 05-12-2008, 07:05 PM
yadac123
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
if you use the dx7 the swash should be 1 servo because the g2's pitch is controlled by one servo and it's mCCPM.
Andy
yadac123 is offline
Old 05-13-2008, 10:24 AM
rftusa2008
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Andy. I'm going to try the stock gyro with digital tail servo. Which one of the servo in xheli.com fit the bill..http://www.xheli.com/servos.html? I'm also replacing the stock cyclic servos. I don't know what to order. I'm getting the lipo/esc/motor combo from xheli. Will my stock lipo that came with my G2 will still work? It is exceed 11.1 1200 mah. I don't know what the C rating is. Thanks in advance.
Old 05-13-2008, 03:50 PM
yadac123
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you are ordering the upgrade combo then don't use the stock battery because it's too low C rating.
If you want to go digital for tail get this. http://www.xheli.com/ra12grmipldi.html
Andy
yadac123 is offline
Old 05-13-2008, 05:26 PM
rftusa2008
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Andy. How about the cyclic servos? I need to replace them but what size? Thanks in advance.
Old 05-13-2008, 05:28 PM
yadac123
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
they use 9G but we do not have it for now but only the stock ones.
Andy
yadac123 is offline
rftusa2008
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Old 05-13-2008, 05:30 PM
rftusa2008
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Andy!
Contact Us Archive Advertising Cookie Policy
