Exceed Raptor G2 rear servo...
I ordered Esky 8g servos to replace my G2 servos from XHELI. Front servos fits but it binds with the outrunner motor upgrade. I'm using the old ones. The back servo, not the tail servo, is stripped and no longer good. My question is, is the 8g servo good enough? The 8g servos look smaller than the original servos for the G2 but actually fits in the servo mounts.
RE: Exceed Raptor G2 rear servo...
they are basicly the same both are equal but the only difference is the mounting case. You can move the esky 8g to the tail and get the tail servo up.
Andy
Andy
Thanks Andy. I only have one good original servo working and will use that for front right. The cable of the ESKY binds to the out runner motor. I don't have problem with binding on the original servo. I'll use the ESKY in the front left and back. The digital tail servo is installed and is working as expected with the original gyro. Thanks for your help.
