Art tech falcon 400
SK, CANADA
Art tech falcon 400
My cousin has recieved a Falcon 400 for christmas and we can't get the gyro to iniatlize,we have tried turning the tx on in heading hold and non-heading hold and turning the heli on,throttle trim set at lowest point,then turning the heli on....we get a red led on the gyro but no movement from the tail servo,bypass the gyro and connect the servo directly to the rx and the servo works,so we know the servo works.....could it be he got himself a faulty gyro,or are we over looking something?
RE: Art tech falcon 400
You did a great job by bypassing the gyro to test the servo, so we know the servo is working. ok there are 2 wires from the gyro did you make sure you plug the 3 pin connector into the rudder channel, ch 4, and the other one into the gain chan, ch5.
Let me know as both connector need to be connected to work.
Andy
Andy
SK, CANADA
Ya we had to plug the rate wire into channel 5(it was tied and not plugged into the RX) and no luck there either,although I received a text from my cousin today stating he figured it out,turns out we had something plugged into the wrong place.I know we had the gyro plugged into 4 and the single wire rate into one of the three prongs on 5,is it possible we had the single rate wire plugged into the wrong prong,of the three available?I'm now a two hour drive away from him and not exactly sure as to what fixed his problem
Yes if you plug the single wire into the wrong pin, it will not work. You must plug into the signal pin. Look at other servo, the signal pin is usue the white color wire.
Andy
Andy
