Exceed G2 speed controller setup ??
Just installed the replacement 30amp volcano series in my G2 do i have to program it or is it already done. I had to solder the bullet connecters and dean connecter on , I turned on the heli everything works is this going to be ok???
RE: Exceed G2 speed controller setup ??
which brushless motor did you use? you might need to program the timming on the esc for the brushless motor. Please refer to your ESC manual.
Andy
Andy
