Exceed RC Support - Helicopter Discuss all Helicopter Support for items purchased or will be purchasing at Exceed RC.
All in 1 receiver with new motor
Reply
Old 09-12-2008, 05:52 AM
RandyS
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default All in 1 receiver with new motor
As soon as the new motor arrived (thanks again Andy), I eagerly installed it, (minimum clearance, no binds) plugged it in, checked everything out and fired it up. Got about 1/8 of a rotation and then nothing. All servos and the tail motor function as expected.
So I do a resistance test on both the new and old motors to compare. The old motor tests like a diode - resistance in one direction, infinate in the other. I assume either a short or open motor winding.
The new motor gives me varying resistance in both directions - windings and capacitors looking good.
This leaves the all-in-one reciever/gyro etc. 0 volts coming out of the main motor lead at all stick positions.
So I'm wondering if the old motor shorting caused the electronics supplying voltage to the main motor to fail and if so, if this would be covered under warranty.
Randy.
RandyS is offline
Old 09-12-2008, 07:38 AM
Disney1
Disney1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: All in 1 receiver with new motor
You are saying that you have a 4 in 1 or similar. What heli do you have? I assume that you have a motor driven tail rotor. dose the tail rotor spin up with throttle? If so just swap the plug so that the tail rotor is pluggd in to the main motor plug and see it the tail rotor spins up then. If it will not spin up than you have a burned out 4 in 1.
When I used to fly a Falcon 40 I had a 10 amp fuse in line from the motor to the 4 in 1 to prevent this problem.
R[8D]N Sr
Disney1 is offline
Old 09-12-2008, 06:31 PM
yadac123
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
does ur tail motor work? put it into the main motor and see how it goes.
Andy
yadac123 is offline
Old 09-12-2008, 08:39 PM
RandyS
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The heli is an Eagle 50. The tail motor does not spin with throttle up.
Randy.
RandyS is offline
Old 09-15-2008, 06:55 PM
yadac123
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
but you know for sure that your tail motor works right? if yes then it's a receiver problem.
Andy
Quote:
ORIGINAL: RandyS
Randy.
yadac123 is offline
Old 09-16-2008, 01:41 PM
RandyS
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Tail spins with voltage applied yes. How do I go about getting a replacement receiver?
RandyS is offline
Old 09-17-2008, 05:29 PM
yadac123
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
what's your order number so I can issue rma and exchange you with a new receiver.
Andy
yadac123 is offline
Old 09-17-2008, 05:52 PM
RandyS
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Order # sent in a PM, thanks Andy.
Randy.
RandyS is offline
Reply
Display Modes
