Exceed RC Support - Helicopter Discuss all Helicopter Support for items purchased or will be purchasing at Exceed RC.
i need help: my exceed dont have force to fly
Reply
Old 09-17-2008, 02:44 PM
dianes
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default i need help: my exceed dont have force to fly
My exceed g2 dont take off but does not have sufficient trottle . The batteries are full, i will the trottle curve adjustment as it says the manual to it to increase the force, but I have not been successful. Please i need your help
dianes is offline
Old 09-17-2008, 05:25 PM
yadac123
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: i need help: my exceed dont have force to fly
In normal mode, disconnect you main motor, low trottle your pitch should be 0, center trottle your pitch should be 5 to 6, max trottle your pitch should be 9 to 10
Andy
yadac123 is offline
Old 09-17-2008, 05:44 PM
dianes
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thank you for your help , but you can give me a more detailed explanation, step by step?
I disconnect the main motor with the battery connected and turned on the transmitter?
Diego
dianes is offline
Old 09-17-2008, 07:39 PM
yadac123
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes turn on your TX (Radio) and turn on your heli. Disconnect the motor to ESC. Now it's safe to do testing. trottle up and down and you'll see the pitch servo moving and that servo controls your pitch. You'll need a pitch guage to measure the pitch of your main blades.
here's some reference: http://www.littlerotors.com/setup/pitchsettings.aspx
Andy
yadac123 is offline
Old 09-18-2008, 07:13 AM
dianes
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks Andy, did you khow how is the original manufacturs setup for 10,11 and 12 tx. my problem is the septup the trotlle, pich
and gyro.
Diego
dianes is offline
Old 09-18-2008, 07:10 PM
yadac123
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You can't get it back to default and even I can't and it needs to be done at the factory but you don't need that to be done. #10 should be off so you can adjust your pitch. Please refer to your manual. You can only adjust one of these fuctions one at a time.
I suggest you start with 10 and setup to 12 oclock.
Andy
ORIGINAL: dianes
and gyro.
Diego
yadac123 is offline
Old 09-22-2008, 03:13 PM
dianes
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
when testing trottle up and down with motor disconnected i don´t see the pitch servo moving (which is behind the engine) the heats but not Servo have any movement with the TX. Additionally when move the throttle up and down the servo that moves the tail rotor.
I do that? Thanks.
dianes is offline
Old 09-22-2008, 04:21 PM
yadac123
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
since your pitch servo is not moving it might be back. Can your put another servo onto the same channel and test it out.
Andy
ORIGINAL: dianes
I do that? Thanks.
yadac123 is offline
Old 10-07-2008, 09:14 AM
dianes
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I put the new servo and working, but i have a problem: the left stick of the TX is inverted: down is trottle and up is off. What happen?
Diego
dianes is offline
Old 10-07-2008, 03:32 PM
yadac123
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
so you are tell me if your push the left joystick up the motor slow down and push down the motor speed increases?
please make sure your dip switches on the back of the transmitter is : 2, 4, 6, 7 ON and the rest are all OFF.
Andy
yadac123 is offline
Contact Us Archive Advertising Cookie Policy
