Exceed RC Support - Helicopter Discuss all Helicopter Support for items purchased or will be purchasing at Exceed RC.
Setting pitch curve on stock TX for G2
Reply
Old 10-08-2008, 10:28 AM
hrdcoreglf
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Setting pitch curve on stock TX for G2
When setting pitch curve with stock Tx, do you set 0 trottle pitch then shut off everything move throttle to half turn back on and set pitch, same for full throttle. Or can you set pitch at each throttle position in one attempt?
hrdcoreglf is offline
Old 10-08-2008, 08:11 PM
yadac123
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Setting pitch curve on stock TX for G2
I'm sorry I don't understand what you are trying to ask. when you setup the pitch at low trottle it should be 0. move your trottle to center and pitch should be 5 to 6.
hope this clears.
Andy
yadac123 is offline
Old 10-08-2008, 09:32 PM
hrdcoreglf
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What I mean is, in the manual it says to make your adj. with the ( I believe ) #12 DIP switch to the ON pos. and make adj.. To save setting turn DIP switch to OFF pos. Do I have to turn it on and off at each throttle pos., or do I just do it all at one time with the switch on do all of the throttle pos. and then shut off #12 DIP switch to save settings. I just want to verify that I understand setting pitch curve, I start at 0 throttle and set the pitch gauge at proper deg. of pitch and adj. pitch on Tx so that the gauge is level with flybar. I do this at each throttle pos. and then save settings. This is my first heli and I am trying to get this heli in the air, I bought a used G2 to learn on, It was cheap I couldn't pass it up. I just need a little help setting up.
Old 10-10-2008, 05:38 PM
yadac123
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
dip switch #12 is gyro adjustment and it's not pitch. You should adjust one at a time. if you are adjusting #12 then #10 and #11 should be OFF. This applies to #10 and #11.
Andy
yadac123 is offline
Old 10-14-2008, 04:03 PM
dditch
dditch's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
try
www.rcdiscuss.com
Set up your pitch curve first.
only flip one dip switch at a time.
Set up the pitch curve w/ the motor wires disconnected.
Pitch limits go first, then set up the throttle knobs while flying. Lots of trial and error.
If you are a beginner, then the Heli should have been ready to go when you got it.
If you've messed w/ it, then set your pitch limits so that the servo is not binding at the end points.
get a pitch gauge.
Read some threads on rcdiscuss then post a new question.
Good luck
dditch is offline
Contact Us Archive Advertising Cookie Policy
