315MM ROTOR BLADES
TN
315MM ROTOR BLADES
Andy - Is it possible to use 315mm main rotor blades on a Raptor G2? I set my pitch to +5 degrees at mid throttle, and it takes a lor more throttle to get it up in the air. Is that too much? On my Belt CP, I can lift off at mid throttle with a pitch of +3 degrees. I use 325mm blades on my Belt CP. I'm sure the larger blades will give me more lift capability. I just don't want to overstrain the motor. Thanks for your input.
