Exceed RC Support - Helicopter Discuss all Helicopter Support for items purchased or will be purchasing at Exceed RC.
gyro problem after upgrade G2
Reply
Old 08-28-2009, 02:05 PM
rotorkat
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default gyro problem after upgrade G2
I just recently upgraded a G2 from brushed to brushless outrunner along with the required brushless speed control. It spools up great with awesome power. Now the tail rotors are not holding heli true drifting slowly counter clockwise. The tail blades are spinng the right direction. I would like a response from Andy. Andy, what should I do? Thanks
rotorkat is offline
Old 09-04-2009, 11:53 AM
yadac123
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: gyro problem after upgrade G2
if the tail is drifting counter clockwise do you mean the head is spinning left? if yes, then this is really a easy fix. You got too much left rudder, simply apply right rudder and observe the tail servo arm and which direction is it moving? into the frame or away from the frame? The move the servo along the same direction as the arm to offset the drift. Trial and error and you must do this until the drift slowly goes away. WHen you move the servo on the tail boom do so in small increments in 1 to 2 mm at a time.
Andy
yadac123 is offline
Reply
Display Modes
