Exceed G2 "SE" 2.4GHz won't initialize
TX
I just got one of these, the prob. I'm having is when I turn on the transmitter and then plug the battery in on the Heli, the heli never initializes, any input on this would be greatly appreciated. Thank's
RE: Exceed G2
The radio system you have is made by walkera so a special attention is needed here. To start, you must connect the battery to the heli first. Put the left joystick down and then to the right of it, put the speed trim down. Then turn ON the radio, move the right joystick in a circular direction to trigger the bind.
Andy
Andy
My Feedback: (213)
RE: Exceed G2
ORIGINAL: thundervee
Andy, thanks for the help that was the prob. it works fine now, I even ran the first battery through it without breaking it,lol
pete
TX
RE: Exceed G2
I like it alot, in fact I'm thinking about buying a second one, Yes this is the first heli I have ever had, my suggestion is spend plenty of time on the simulator before you try to leave the ground with it and you'll be fine. Do not get in a hurry to try to fly it, get used to it first.
