some 1 help exceed G2 Pitch setting
Hi, First time posting the question on this fourm.
Q1. what are the DIP Switch setting for wk-0701 transmitter for G2 Raptor. Q2. when setting up pitch on wk-0701 transmitter for G2 raptor what is the DIP switch setting is. which ones to off and witch ones to on. thank you in advance. I Realy need help on this. Reason i posted questions above heli is not lifting off when Throt is in middle. |
RE: some 1 help exceed G2 Pitch setting
please help for setting pitch for G2 Raptor
ON 2,4,6,7 rest are off
It doesn't have to be in the middle. It's the combination between trottle curve and pitch curve. Thanks Andy |
50 % throttle still grounded. when checked the pitch blades turn a little. need more help.
Thanks |
then adjust dip switch #10 to be safe disconnect your main motor. Adjust the knob and trottle up and see the changes on the pitch. Your pitch slider should move up to make a positive pitch.
Andy |
OK HERES HOW U SET YOUR PITCH CURVE WITH WK-0701 TRANS.
TRANS OFF, BATT UNPLUGED SET FLIGHT MODE TO N SET V1 DIAL TO 0 TURN DIP SWITCH #10 TO ON, MAKE SURE #11 + #12 ARE OFF TURN TRANS ON AND PLUG IN BATT TURN V1 DIAL CLOCK WISE TO 40% START THERE 60%MAX THIS WILL INTRODUCE 40% PITCH @ 50% THROTTLE TURN DIP SWITCH #10 OFF TO SAVE SETTINGS TRY THAT LET ME KNOW HOW U MAKE OUT. QUICKCINCH; |
My V2 is working as V1. V1 has no response. I do not know what's wrong.
TRY SETTING V2 DIAL TO 0 AS WELL THEN ADJUST V1 TO 40 - 50% TURN DIP SWITCH 10 OFF. IF THAT DOSN'T WORK TRY SETTING V2 TO THE SAME SETTING AS V1, TURN DIP 10 OFF. LET ME KNOW ! QUICKCINCH.
