Falcon 40 shaking violently
I Broke one of the main rotor blades so i replaced it.
Now the main rotors and Paddles are all straight and level but the heli is shaking very badly. Does anyone have any ideas why it could be doing this?\ Thank you for your help[8D] |
RE: Falcon 40 shaking violently
3 things.
Main blades can not be too tight to the blade holder and they should be snug. flybar needs to be equal both side, use a ruler. You should remove both paddles and then apply them 180 degree flat. Main shaft should be stright and once crash there is a chance that could be bent already. Remove it and roll it on a flat surface and see. Andy |
