Eagle main motor not getting any juice?
I got my eagle 50 checked everything worked great. hit the 3d switch by mistake the throttle was all the way down it went from no power to all power in like 2 sec. while it was on the ground main rotor blades got stuck on the ground main motor started smoking it just melted pos. and neg. wires and cracked the Restrictor the lil thing between the pos and neg on main motor everything works but the motor is not getting any power from the receiver could i have shorted the receiver. I got to fix this heli cuz it was out of the box 5 min and broke. didnt get to even try to fly it yet. some on plz help cuz i want to get this bird in the air THX.
RE: Eagle main motor not getting any juice?
this is a perfect example of how motor is burned. Main blade was blocked by hitting the ground. This stopped the brushes moving while a large current is moving thru the motors.
Can you please make sure the receiver is still working. Connect the tail motor to the main motor port and trottle up. If your receiver is still working your tail motor should spin. Andy |
1 Attachment(s)
Andy, I need your help again. I finally learn how to hover my Eagle 50 and was beginning to move in the air a little. The thing that happen was when I was about to land I got to close to a stick and the blade hit it and my canopy also cracked ( I have a mess, I know). I took the thottle down quickly to save the motor tat you sent me. What my problem is is that now when I begin to thottle up, it starts to wobble on the ground. I check to main shaft and everything looks godd but one of the pins that is connected to the rotor that turns the blade is some what bent. I went to a couple of hobby shop down here, but now one wahts to look at it because they say that they don't carry the parts and it is a internet heli , and not one that you can buy in the store. What should I do at this point?
Please help! |
in that case you'll need 50H03-38-1 as replacement parts and you can get them here: http://www.xheli.com/exrcea50rche.html
Andy |
ok, do I need ant special tools to put them on? Is there a diagram that shows you how to put them on?
here: http://site.exceedrc.com/resource/pr...eagle50-ex.jpg
just use a regular screw driver and that's it. Andy |
ok, well I glad that you gave me the right part number, because I had the wrong one. I hope that that will fix the wobbling and I can continue to fly. I think what I'm going to do is get the Real FlightG4 and use that until I get better. do you know where I can get that and a good price?
get the sim like you said and then get a flyable heli. what your hobby shop wanted to say is that it's junk. because it is. just don't let this heli run you out of the hobby. it's not as hard as this heli makes it. just my 2 cents. i speak from experience. ok i'll leave the exceed section like i have their products. just count how many people come on here and praise this heli and how many have complaints. it's like 100 complaints to well 0 compliments. im out
I don't really understand what you are saying? Please explain
