Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > Exceed RC Support - Nitro Cars
Reload this Page >
Off Road Truck (DD Red) Radio Car 1/10 Exceed RC Brushless PRO 2.4Ghz Electric Infini
Exceed RC Support - Nitro Cars Discuss all Nitro Car Support for items purchased or will be purchasing at Exceed RC.
Old 02-26-2018, 11:18 AM
yadac123
Default Off Road Truck (DD Red) Radio Car 1/10 Exceed RC Brushless PRO 2.4Ghz Electric Infini
https://www.nitrorcx.com/51c803-pro-ddred-24ghz.html
The 1/10 scale Infinitive EP has undergone a complete power train overhaul and has emerged as a completely new, beast of a monster truck. The engineers at Exceed RC have aggressively upgraded the Infinitive EP to keep it at the peak of the monster truck class. What did Exceed do to supercharge the already solid Infinitive EP platform? The new Infinitive EP now features mind-blowing increases in speed, an incredible amount of customization, and exceptional durability. Exceed RC has made various improvements on the Infinitive EP platform based on feedback from existing owners. The new platform provides more room for electronics, easier access to the differentials, more control over suspension adjustments, a more powerful programmable ESC, and sealed gears. Designed using the latest in Brushless technology, the Infinitive EP is comparable to competition level monster trucks at a fraction of the price.
The Infinitive EP is equipped with robust and durable front and rear bumpers that protect the main body of the truck. It is also equipped with aluminum threaded shock bodies which allows the preload of the springs to be quickly and easily tuned. The camber and toe are also easily adjusted through the use of aluminum turnbuckles. These combined features allow the user to quickly and easily tune the suspension geometry, letting the user get the most out of the Infinitive EP platform.
The Infinitive EP is powered by a sensorless Brushless Motor rated at 3300KV @ 12Turns and a programmable 45amp ESC, that’s capable of handling 4-7s Nickel batteries or 2s LiPo batteries. This new power train is easily capable of providing reliable and consistent power for extreme off-road driving. Best of all, the motor and transmission are both completely sealed to prevent dirt and grime from getting in and causing damage. This motor has been proven to be both durable and reliable, making the Infinitive EP a welcomed addition to the latest Exceed RC line. With 20 exciting color schemes to choose from the Infinitive EP is sure to be a favorite for RC enthusiasts everywhere.
SPECIFICATIONS:
Model: Exceed-RC Infinitive EP Electric Truck (Upgraded Version w/ Brushless Motor & Brushless ESC)
Engine: KV3300 Brushless Motor
Transmission: Single speed with Reverse
Gear Ratio: 1:10.3
Drive System: Four Wheel Drive
Radio System: Two Channel 2.4Ghz
Battery: 8.4V 3000mAh Ni-Mh
Length: 400mm
Front Track: 150mm
Rear Track: 150mm
Overall Height: 185mm
Wheelbase: 275mm
Front Shock Length: 95mm
Rear Shock Length: 95mm
Front Tires: Off Road
Rear Tires: Off Road
Wheel Width: 60mm
Wheel Diameter: 120mm
Brake Type: Reverse Braking
Suspension Type: 8 bodied oil filled shocks
What's Needed
8 AA Batteries. Everything else is included
Required to Run:
4 AA batteries for Transmitter
**Note**
45amp ESC is rated for 4-7s Ni-Mh batteries or 2s Lithium polymer. Using a battery with higher voltage can damage esc or motor.
