Exceed RC 1/8th Scale Alpha Blue MadFire .21 Nitro Power 4WD Buggy 100% Ready to Run
https://www.nitrorcx.com/52c62-madfi...ite-24ghz.html
The new generation of 1/8 Buggy are here with much newly added features and functions. Everything from the ground-up has been reinvented and modified to enhance the delight of having fun with the RC once again.
This massive 2.4Ghz 1/8 MadFire Buggy comes with Level .21 engine for speed of swiftness, polished aluminum chassis to provide clean look as well as sturdiness, adjustable shocks to have perfect landing, a bigger fuel tank that can hold 125cc. The impressiveness of the MadFire can be seen right out of the box when examine at first glance from the well-built interior to the magnificent exterior designs. From the front bumper to the back bumper all pieces have been build to last. Included in the MadFire are aluminum muffler for superior protection and better looks, and heavy duty metal gear steering servo so you don?t have to worry about it breaking. Even the rims are now hardened chrome rims and colossal tires to triumph over the world. Use the MadFire to climb off road terrain, stony hills, rocky backyards, or wherever the road may take you. For the MadFire will lead the way to new standards for the RC world and conquer all.
The 4WD Engine-powered Monster Buggy MadFire will Push your Imagination into overdrive!
2.4Ghz Sport Radio & Engine 21 Level
WheelBase:15"
Weight:5.2kg
Polished 6061 Aluminum Chassis Plates
Massive pre-glued 4.75" Tires Mounted on Hardened Chrome Rims With 17mm Hex Hub
1-Speed Transmission
Heavy Duty Metal Gear Steering Servo
125cc Flip-top Fuel Tank
Adjustable Threaded Aluminum Shocks
WheelBase:15"
Weight:5.2kg
