Iron Track Electric Barren 1/18th 4WD Desert Buggy Ready to Run (Blue) RC Remote Cont
https://www.nitrorcx.com/16c668-blue-rtr.html
Iron Track introduces its newest 1/18 scale Barren desert buggy. This small scale buggy has all the key features of bigger 1/10th scale buggies such as shaft driven four wheel drive, durable differentials, oil filled shocks, and robust design. It's all packed into a buggy that will fit in the palm of your hand. The scale roll cage will take anything that you can throw at it. The Barren is also fully equipped with a 2.4ghz radio system, powerful 370 brushed motor, 120amp burst rated speed controller, and a 7.2v 800mah Ni-Mh battery pack, so it's completely ready to run with the exception of adding AA batteries for the radio. The compact buggy chassis lets you take on other off-road vehicles in wheel-to-wheel action, allowing you transform your yard into a fun offroad course!
Electronics:
2.4ghz Transmitter
2 in 1 Electronics Speed Controller and 2.4ghz Receiver
7.2v 800mah Ni-Mh Battery
370 Brushed Motor
1.1kg Precision Steering Servo
Features:
Scale roll cage with driver
Molded protective gear cover
Molded tub chassis with optimized weight distribution
4 oil-filled rebuildable shocks with progressive springs
Special titanium anodized shock caps
Fully independent double A-arm wishbone suspension
Tough C-hub steering knuckles
Tough and efficient 4WD shaft driven drive train
Low friction ball raced bearing
4 high-traction multi-block tires
Attractive 5 spoke wheels
Factory-finished pre-cut body
Front and rear molded bumpers
Twin point steering with integrated servo saver
Specification
LENGTH: 225 MM
WIDTH: 180 MM
HEIGHT: 72 MM
WHEELBASE: 166 MM
Electronics:
2.4ghz Transmitter
370 Brushed Motor
Features:
Specification
LENGTH: 225 MM
WIDTH: 180 MM
HEIGHT: 72 MM
WHEELBASE: 166 MM
