WLtoys V666 5.8G FPV 6 Axis 2.4G Quadcopter Drone with HD Camera Monitor RTF Green w/
https://www.nitrorcx.com/28h-v666-cy...green-4gb.html
The V666 is designed to be a simple ready to go FPV platform out of the box. The quadcopter flies just as well as the previous versions of this unit but this time it'll come with a preinstalled 720p camera and 125mW video transmitter. Receiving this signal will be the included LCD screen that mounts directly to the transmitter. The camera is attached to a anti vibration mount that helps hold the camera steady so you can avoid shakes and bumps in your video footage. The on board 6 axis gyroscopes will ensure stable and controllable flight. This unit is perfect for someone that wants to get into FPV flying by don't want to purchase the individual components needed to convert their existing aircraft FPV capable.
Specifications:
Remote Control: 2.4GHz Wireless Remote Control
Product Size: 525mmx525mm
Channel: 4-Channels
Mode: Mode 2 (Left Hand Throttle)
Controllable Distance: 300-600ft
Video range: up to 600ft
Transmitter Power: 4 x 1.5V AA battery(not included)
Charging Time: 60-100mins
Flying Time: > 6mins
Package Contents:
1 x V666 RC Quadcopter,
1 x 2.4G Transmitter,
1 x 7.4V 1200mAh Battery,
1 x Camera Vibration Absorber,
1 x 5.8G FPV Monitor,
1 x Card Reader,
1 x 4GB Card,
1 x US Balance Charger,
4 x Propeller,
1 x USB Cable
Caution:
NEVER CONNECT THE VIDEO TRANSMITTER WITHOUT INSTALLING THE ANTENNA FIRST. YOU CAN FRY THE VIDEO TRANSMITTER DOING SO.
Specifications:
Channel: 4-Channels
Package Contents:
1 x Card Reader,
1 x 4GB Card,
4 x Propeller,
1 x USB Cable
Caution:
