AeroSky 550 Drone Yellow 6 Channel Hexacopter Almost Ready to Fly RC Remote Control R
https://www.nitrorcx.com/05h103-hex-p3-yellow-arf.html
The AeroSky 550 Hexacopter is a multi-rotor machine designed for amateur to experienced pilots. It is driven by six 920KV brushless outrunner motors and supported by six brushless 40 amp Hobbywing Skywalker electronic speed controllers. This impressive power system nets a payload capacity of up to 3 lbs. This allows the machine to carry FPV camera systems or other recording devices that can be applied to entertainment, aerial photography, and other aero activities. The frame structure consists of frame arms that adopt ultra strength material and design providing enhanced rigidity and crash worthiness. The arms are also color coordinated which makes it easier for the pilot to recognize the orientation of the craft at distance. The main boards are constructed with high strength compound PCB frame board, which makes wiring of electronic speed controllers and battery leads safer and easier. The optimized frame design also provides abundant assembly space for autopilot systems.
The heart of the machine lies within the MWC flight control board. This programmable board via onboard USB port is fitted with a ATmega2560 CPU, MPU6050 Gyro and Accelerometer, HMC5883 MAG, and MS5611 Barometer.
This almost ready to fly version has all the essential electronics installed. You will need a 14.8v 2200mah lithium battery, lithium battery capable charger,? six channel radio system, and complete the programming and settings for the quad.
Features:
Ultra Strength Material
Integrated PCB wiring
Huge Assembly Space
Gorgeous Frame Arms
Specifications:
Dimensions: 55x55cm
Height: 10cm
Weight: 1200g ~ 2400g
Six 10x4.5 inch Propellers
Electronics:
Motor: Six 2212 OutRunner Brushless 920KV Motors
ESC: Six 40A Hobbywing SkyWalker Brushless Electronic Speed Controllers
MWC Flight Control Board
CPU: ATmega2560
GYRO & ACC:MPU6050
MAG:HMC5883
Barometer:MS5611
USB in board
Required to Fly:
8 AA Batteries
Program the MWC Board
6CH Radio Transmitter
6CH Radio Receiver
14.8v 2200mah Battery
Lipo Battery Charger
Features:
Huge Assembly Space
Gorgeous Frame Arms
Specifications:
Dimensions: 55x55cm
Height: 10cm
Electronics:
CPU: ATmega2560
GYRO & ACC:MPU6050
MAG:HMC5883
Barometer:MS5611
USB in board
Required to Fly:
8 AA Batteries
6CH Radio Receiver
