WLToys Dragonfly 3 Q696-A FPV 5.8G 1080P 2-axis Gimbal Air Press Altitude Hold RC Qua
https://www.nitrorcx.com/28h-x696a-1080-fpv-white.html
The new WLToys Dragonfly 3 Q696 has features that is commonly found on more advanced models in a more affordable package. It comes equip with telemtry for real time flight data and a 2 axis gimbal.
With the 2-axis gimbal, the 5MP camera can be used for taking smooth 1280 x 1080P videos and 1600 x 1200P photos. You can also control the camera angle by the transmitter, so you can get the perfect shot no matter where you're at. The 5.8G FPV camera allows you to see the real-time image on the 4.3 inch large screen of the FPV monitor.
With the use of 2.4ghz technology radio system has the benefit of longer control distance, strong anti-interference technology, low power consumption, and rapid response times. Using spread spectrum technology for further remote distance, best anti-interference ability, least power consumption. You could fly more helicopters at the same time, its reaction speed is 100 times faster than other radio control. The screen on the transmitter will allow you to know the real-time voltage of the Q696-A, speed, height and flight duration.
Features a altitude hold mode which enables your drone to stay at the same height, without falling down all of a sudden provides a more stable flight and more steady aerial image.
Features headless mode which means that once this mode is activated, pulling the direction of the stick back towards you will bring your aircraft back home to you no matter is orientation, front, back, or side. This makes flying back to yourself when you lose sight of it much easier!
One key return function makes it easy to find its way home, the 360 degree flip mode is a push of a button away, allowing the user to perform flips and rolls.
The plug-in style 7.4V 2600mAh 20C LiPo battery will give you up to 13 minutes of high-speed flying.
Specification:
Detailed Control Distance: 100-150m
Compatible with Additional Gimbal: Yes
FPV Distance: about 100m
FPV Screen Size: 4.3 inches
Monitor runtime: 60 mins on full charge
Moitor working Frequency: 5.8G
Transmitter Power: 4 x 1.5V AA battery(not included)
Battery: 7.4V 2600mAh 20C LiPo ( included )
Flying Time: 10-13mins
Charging Time (h): 200mins
Camera Pixels: 5MP
Video Resolution: 1280 x 1080P 30fps
Camera Gimbal: 2-Axis
Includes:
1 x WLtoys Q696 Quadcopter (with Camera and Gimbal)
1 x Transmitter
1 x Wall Adapter
1 x Balance Charger Box
1 x 7.4V 2600mAh 20C LiPo Battery
8 x Propeller
4 x Propeller Guard
1 x 5.8G FPV Monitor
1 x Antenna
1 x Screw
1 x USB Charging Cable for FPV Monitor
1 x English Manual
Specification:
Camera Pixels: 5MP
Includes:
1 x Transmitter
1 x Wall Adapter
8 x Propeller
4 x Propeller Guard
1 x Antenna
1 x Screw
1 x English Manual
