Sky Cruiser 4 Channel 6 Axis Gyro Quadcopter Drone Flying Machine 2.4ghz Ready to Fly
https://www.nitrorcx.com/28h-1314-sk...ser-black.html
The Sky Cruiser quadcopter is the perfect machine for those curious about quadcopters and space machines. Designed with simplicity in mind, it is light weight and durable. These features benefit the aircraft with easy and stable handling. Constructed of durable materials and graphite booms, the light weight enhances the crafts power to weight ratio. The 4 rotors are driven by 4 motors protected in plastic housings. The rotors are also gear driven which relieves the stress on the motors. The rotor blades are also protected by a molded foam shell that absorbs impacts and protects the blades during collisions with obstacles. The Sky Cruiser handles exceptionally well. With the help of an on board gyro and adjustable control sensitivity, the Sky Cruiser is perfect for pilots of different skill level and ages. This aircraft is agile, and it has the ability to do flips and tricks. With the push of a button on the transmitter the aircraft enter "trick mode" allowing the pilot to do flips and rolls. The Sky Cruiser transmitter features a 2.4ghz radio system. This means you don?t have to worry about signal interference and you have the ability to fly many of these at one time. LED lights mounted on the front and rear of the aircraft allow the pilot to achieve better orientation during flight and enhances flight ability during low light situations.
Sky Cruisers Features:
LED lights
2.4Ghz Transmission enables interference free operation
Full Proportional Remote Control with Built-in 6 axis GYRO System
Special design cover with durable material, provides more protection
High capacity battery included, provides longer flight time
Specifications:
Charging Time : About 60 minutes
Flying Time : About 5-6 minutes
Controlling Distance: About 50 meters
Product size: 62 x 46 x 14 CM
2.4Ghz control
Battery for Quadcopter: 7.4v 350mAh Li-Poly
Battery for Controller: 4 x AA
Package Includes:
1 x Sky Cruiser? RC Quadcopter
1 x transmitter
1 x battery
1 x charger
4 x spare propeller
Required to Fly:
4 AA Batteries for Transmitter
LED lights
Specifications:
2.4Ghz control
Package Includes:
1 x transmitter
1 x battery
1 x charger
4 x spare propeller
Required to Fly:
