Tacon 2030-18T Brushless Motor 5200KV for 1/16 1/18 Car Trucks
https://www.nitrorcx.com/96m256-2030-5200kv-18t.html
Net Weight (g): 52.6
Watts: 130
Outer Diameter (mm): 24
Length (mm): 33.5
Stator: 15MM
No of cells (lipo): 2
max efficiency (%): 85%-89%
max efficiency current : 12
no load current (A)/7.4V: 1.2
Internal Resistance (mohm): 0.0733
Shaft Diameter (mm): 2.00
Shaft Length (mm): 10
KV (RPM/VOLT): 5200
Turns (for cars)Poles: 18T/2POLES
Max Voltage: 8.4
Wire Size: 0.34
Bullet Connectors: YES
Bullet Connector Size: 3.5MM
design for: FSD
Watts: 130
Length (mm): 33.5
Stator: 15MM
KV (RPM/VOLT): 5200
Max Voltage: 8.4
Wire Size: 0.34
design for: FSD
