Tacon 540XL 2848 Brushless Motor 4300KV for 1/10 On-Road RC Race Car
https://www.nitrorcx.com/96m11-car-2848-4300.html
Net Weight (g): 171
Watts: 400
Outer Diameter (mm): 35.8
Length (mm): 50
Stator: 25MM
No of cells (lipo): 2
max efficiency (%): 85%-89%
max efficiency current : 46
no load current (A)/7.4V: 2.4
Internal Resistance (mohm): 0.0127
Shaft Diameter (mm): 3.175
Shaft Length (mm): 15
KV (RPM/VOLT): 4300
Turns (for cars)Poles: 9T/2POLES
Max Voltage: 8.4
Wire Size: 0.34
Bullet Connectors: YES
Bullet Connector Size: 3.5MM
design for: FSD
Net Weight (g): 171
Watts: 400
Length (mm): 50
Stator: 25MM
KV (RPM/VOLT): 4300
Max Voltage: 8.4
Wire Size: 0.34
design for: FSD
