Exceed RC 1/10th 2.4Ghz DD Blue Brushless Short Course Rally Monster Electric RTR Rac
https://www.nitrorcx.com/51c809-pro-...ep-ddblue.html
The popular 1/10 scale Short Course class has evolved into an exciting new platform. At each evolutionary step, the Rally Monster Brushless Pro has been improved upon to keep it at the peak of the truck class. So how did Exceed make the Rally Monster Brushless Pro even better? The focus of our improvements was on increasing speed, more adjustability, and increasing durability. Now the updated truck is packed with features that have been suggested by previous truck owners. There's more room for electronics, easier access to the differentials, more control over suspension adjustments, a more powerful programmable ESC, and sealed gears. Designed using the latest in Brushless technology, the result is nothing less than the best Rally Monster Brushless Pro ever.
The Brushless Rally Monster Pro is equipped with robust and durable front and rear bumpers that stay true to a short course style truck. It is also equipped with aluminum threaded shock bodies which allows the preload of the springs to be quickly and easily tuned. The camber and toe are also easily adjusted through the use of aluminum turnbuckles. These combined features allow the user to quickly and easily tune the suspension geometry, letting the user get the most out of the Brushless Rally Monster platform.
The Rally Monster Brushless Pro is powered by a Sensorless Brushless Motor rated at 3300KV @ 12Turns and a programmable 45amp ESC, that’s capable of handling 4-7s Nickel batteries or 2s LiPo batteries. This new power train is easily capable of providing reliable and consistentpower for extreme off-road driving. Best of all, the motor and transmission are both completely sealed to prevent dirt and grime from getting in and causing damage. This motor has been proven to be both durable and reliable, making the new Rally Monster a welcomed addition to the latest Exceed RC line. With 12 exciting color schemes to choose from the Rally Monster Brushless Pro is sure to be a favorite for RC enthusiasts everywhere.
Specifications:
Length:
400 MM
15.7 inch.
Width:
250 MM
9.8 inch.
Height:
160 MM
6.3 inch.
Wheelbase:
275 MM
10.8 inch.
Ground Clearance:
26 MM
1.02 inch.
Gear Ratio:
8.038:1
Diameter Of Wheel:
86*32 MM (F) 86*40 MM (R)
Features:
Robust front and rear bumpers
Adjustable Aluminum Shocks and Spring Preload
Adjustable Camber and Toe Turnbuckles
Aluminum Center Driveshaft
Front/Rear Metal Differential Gears
Suspension Arms With Adjustable Width
Adjustable Servo Saver
2.5mm Aluminum front and rear shock towers
Fully Enclosed Gearbox
Solid Aluminum Upper Deck
Aggressive Off Road Treaded Tires and Chrome Plated Rims
Four Wheel Drive System
Powerful 3300Kv Brushless Motor
Brushless Electronic Speed Controller w/ Built in Cooling Fan
8.4V 3000mAh Ni-MH Battery Power
Specifications:
Suspension: Aluminum body shocks with threaded shock collars
Motor: Fully sealed sensorless brushless motor 3300KV 12Turn
ESC: Programmable 45amp ESC capable of 2s Lipo 4-7s NI-MH with cooling fan
Battery: 8.4v 3000mah NI-MH
Radio: 2.4ghz Exceed RC 2 channel radio system
Required to Run:
4 AA batteries for Transmitter
**Note**
45amp ESC is rated for 4-7s Ni-Mh batteries or 2s Lithium polymer. Using a battery with higher voltage can damage esc or motor.
Specifications:
Length:
400 MM
15.7 inch.
Width:
250 MM
9.8 inch.
Height:
160 MM
6.3 inch.
Wheelbase:
275 MM
10.8 inch.
Ground Clearance:
26 MM
1.02 inch.
Gear Ratio:
8.038:1
Diameter Of Wheel:
Features:
Specifications:
Required to Run:
**Note**
