Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > Exceed RC Support - Nitro Cars
Reload this Page >
1/12 Tacon Ranger Rally Brushed Car Ready to Run 2.4ghz (Blue) RC Remote Control Radi
Exceed RC Support - Nitro Cars Discuss all Nitro Car Support for items purchased or will be purchasing at Exceed RC.
Reply
Old 11-08-2018, 12:25 PM
yadac123
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 1/12 Tacon Ranger Rally Brushed Car Ready to Run 2.4ghz (Blue) RC Remote Control Radi
https://www.nitrorcx.com/25c237-12-r...ally-blue.html
The Tacon Ranger is a 1/12 scale Rally car. It was designed from the ground up with pure performance in mind. Performance features derived from 1/8 scale trucks and buggies have been shrunken down in size and engineered to deliver the utmost performance in a small rally car package. A composite chassis serves as the base of this rally car. Mounted on the front and rear is thick composite shock towers towering over the planetary geared fluid filled differentials. Attached to the robust towers are aluminum capped, threaded coil over, oil filled shocks providing plush and ground hugging dampening. The steering tie rods and upper and lower arms are adjustable for fine tuning of the toe and camber, effectively altering the handling characteristics of the car.
This car has awesome power to weight ratio. Weighing in at slightly over 2 lbs, the vehicle is easily propelled by the 380 sized high performance brushed motor. A brushed electronic speed controller delivers the current efficiently through an included 7.2v 1100mah Ni-Mh battery and charger. The brushed electronic speed controller is lipo ready and can accept 7.4v lipo batteries with a quick switch of a jumper switch. All of this power transfers through a shaft driven four wheel drive system providing ground clawing action through the performance wheels and rally spec tires. We recommend a Gens Ace 7.4v 1800mah lithium battery for an exponential increase in power and efficiency.?
The Tacon Ranger ready to run package also includes a 2.4ghz radio system. With frequency hopping technology, interference is a thing of the past. No longer do you have to worry about your specific channel. The radio system will automatically take care of that for you while you are focused on handling this beast of a machine.
With a body designed with rally car looks and aerodynamic performance, combined with a roof spoiler on the rear hatch. This scale rally machine will put a huge smile on your face when you see it four wheel power sliding through a corner spitting dirt and debris out the rear end.
Features:
1. Tacon design rally spec treaded tires
2. Tacon design slipper pad with adjustable gear cover
3. Aluminum-capped, oil-filled, coil-over, 6061-T6 adjustable shocks
4. Thick composite shock towers
5. Front and rear metal planetary gear differentials
6. Brushed Tacon ESC
7. 380 Brushed Motor
8. 4WD shaft drivetrain
9. Adjustable mini solar servo with saver
10. Steel hinge-pins with rounded foam front bumper
11. Tacon receiver with 2.4GHz technology
12. 7.2V 1100mAh NiMH battery with 3.5mm gilded round connectors
13. 12mm wheel hexes
Specifications:
Scale: 1/12 Tacon Ranger Rally
Length: 395mm (15.59in)
Width: 210mm (8.26in)
Height: 135mm (5.3in)
Wheelbase: 225mm (8.86in)
Weight: 1.08kg (battery included) (2.2lbs)
Tire Type: Tacon Rally Tread
Chassis: Composite
Motor or Engine: 380 Brushed motor
Steering Servo: Solar 655
Gear ratio:8.23
Speed Control: brushed lipo ready
Radio: 2.4GHz Technology
Batteries: 7.2V NiMH with 3.5mm gilded round connector, Charger included
Shock Type: Aluminum-capped, oil-filled, coil-over, 6061-T6 adjustable
Ball Bearings: Complete
Package Contents:
100% Assembled
1x 1:12 Tacon Ranger Rally Car
1x 2CH 2.4Hz Transmitter
1x Battery Charger (100-240V)
1x 7.2v 1100mAh Ni-MH battery
1x Instruction Manual
Required to Run:
AA Batteries for Transmitter
yadac123 is offline
