1/8Th EP Mad Beast Monster Truck Racing Edition Ready to Run w/ 540L Brushless Motor/
https://www.nitrorcx.com/03c503-re-m...brushless.html
The new MadBeast EP is Exceed RC's new entrant to the electric monster truck class and it is ready to smash through its competition. The new MadBeast EP is Exceed's electric-powered counterpart of the ever popular MadBeast monster truck. This new variation comes fully equipped with a revamped brushless powertrain and an improved chassis and suspension design. This new rugged design features improved performance and durability to maximized raw bashing power.
The new MadBeast EP features a rugged 540L brushless motor rated at 2150kv and a 100-amp XeRun Programmable ESC. This new motor is shielded by an huge heat sink to safely allow maximum torque potential. This massive monster truck is powered by dual 7.4v 3300mAh LiPo batteries wired in series to generate a peak 14.8v. The MadBeast is equipped with anodized aluminum chassis plates and roll bar giving this monster a super strong frame. The double aluminum shocks with threaded shock collars that can be found on both the front and rear axles of the MadBeast EP ensure that no terrain is too rough for this beast of a truck. The new slipper clutch design implemented on this truck protects the gears from the abuse of rough terrain. This awesome new platform rides on 6.75 tires with extreme all-terrain tread that adds to the imposing design of this massive monster truck. The MadBeast EP is fully-loaded with upgrades to handle anything you can throw at it and is sure to be the king of the electric monster truck class.
2 Channel 2.4ghz Exceed RC Radio System
540L (36x65mm) 2150kv Sensorless Brushless Motor
XeRun 100A-R Programmable ESC 2-4S LiPo 3A @ 5.75v
ND1009 Metal Geared Steering Servo
Two 3mm thick aluminum chassis plate
8 Aluminum body shocks w/ adjustable threaded collars
Aluminum steering hub
Hardened & Coated Steel Gears
Multi-piece Anti-Sway Bars
Fully Sealed Ball Bearing Set
Robust Slipper Clutch Assembly
Two 7.4v Li-Po 3300mah 20C Cont / 40C Burst batteries included
Pistol 2.4Ghz Remote Control Radio
WheelBase:15"
Weight:5.2kg
This item Does NOT come with Charger
Motor: 540L Brushless Motor
Bearing: Ball Bearing
Length : 21.25 inches (540mm)
Width: 16.34 inches (415mm)
Height : 11.42 inches (290mm)
Wheelbase: 13.98 inches (355mm)
Gear Ratio: 1:19:37
Batteries: 2 x Li-po 7.4V 3300mAh Cont. 20C/ Burst 40C Batteries
ESC: 100A Brushless ESC
Radio: 2.4Ghz Pistol Remote Control
WheelBase:15"
Weight:5.2kg
Gear Ratio: 1:19:37
