Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > Exceed RC Support - Nitro Cars
Reload this Page >
1/8Th (Blue) Mad Code Short Course Racing Edition RTR Ready to Run Rally Car w/ Brush
Exceed RC Support - Nitro Cars Discuss all Nitro Car Support for items purchased or will be purchasing at Exceed RC.
Old 01-11-2019, 02:29 PM
yadac123
Default 1/8Th (Blue) Mad Code Short Course Racing Edition RTR Ready to Run Rally Car w/ Brush
https://www.nitrorcx.com/52c78-re-ma...brushless.html
Designed to look just like the full-size Rally Cars, 4WD Racing Edition that runs in short course off-road series like the other brand models. Team Exceed RC is proud to announce the Mad Code as the latest edition to our line of 1:8 scale, brushless 4WD race truck rally car.
Each Mad Code comes decked out with one of three fully racing style truck bodies, wheels and tires. This is the high-performance R/C Rally car in its' class built with 540L Brushless Motor, Dual Lipo 7.4V 3300mAh Battery, and 80A ESC.
The Exceed RC Mad Code was designed to meet other racing rally cars around the world. It's all here, from the suspension travel, to painted body. The result is the Exceed RC Mad Code, a creation of an unparalleled experience at a level of performance that has never been seen.
Underneath the beautifully finished body, and wheels, beats the heart of a Mad Code. The Mad Code comes fully assembled and ready to go. Team Exceed RC 2.4Ghz Radio system are factory installed. The differentials and shocks come filled with the proper silicone fluids, making it faster and easier than ever to get Exceed RC Mad Code performance out of the box and into the dirt! When we created the Mad Code, we knew we had made something very special.
Features: Mad Code RTR
Molded battery tray supports two ROAR-approved 1:8 scale size 7.4v LiPo battery, servo, and battery tray are removable in one piece for easy maintenance and cleaning
Factory painted and finished short course truck body.
Mounted and assembled scale wheels & tires with foam inserts and bead guards.
Factory-painted and finished short-course truck body
2.4Ghz Pistol Sport Radio Transmitter
Convenient wire routing keeps critical electronic wires out of drive-train components and simplifies disassembly
Alloy steel Turnbuckles for quick adjustability and tuning
Dual Bell-crank steering for more consistent steering and reduced bump-steer on rough surfaces
540L Brushless Motor and HobbyWing 80A-R Brushless ESC (Electric)
Carefully placed battery compartments and center mounted ESC platform and for balance (Electric)
Durable and thick hardened plastic suspension arms
Anodized 6061 3MM aluminum chassis plate
Anodized 4MM Front and Rear aluminum shock tower
Massive pre-glued 4.75" Tires mounted on hardened chrome wheels with 17mm hex hub
Silicon Fluid sealed Front, Center, and Rear hardened and coated steel gear differentials
Heavy duty metal geared steering servo
Adjustable 16MM Big Bore threaded aluminum shocks
Anodized Aluminum Chassis plate stiffeners
Anodized Aluminum differential plates
Anodized Aluminum Steering arm
Multi-piece adjustable anti roll bar front and rear
Full Sealed Ball Bearing Set
Front Constant Velocity Driveshaft (CVD)
Adjustable Front and Rear Roll Center
Motor: 540L Brushless Motor
Bearing: Ball Bearing
Length: 25 inches (635mm)
Width: 11.81 inches (300mm)
Height: 7.68 inches (195mm)
Wheelbase: 14.37 inches (365mm)
Gear Ratio: 1:11:7
Batteries: 2 x Li-po 7.4V 3300mAh Cont. 20C/ Burst 40C Batteries
ESC: 80A Brushless ESC
Radio: 2.4Ghz Pistol Remote Control
