What Brushless Motor & ESC TO Use?
Andy,
I am looking at the Raien Tech site and would like to purchase a brushless system.
I am not sure what to purchace for my application?
I have an Exceed 1/10 th electric truggy with the wheels from the Exceed electric Monster truck installed.
What do the kv numbers represent in relation to torque vrs. speed?
http://www.raidentech.com/brushlessesc.html
http://www.raidentech.com/inrubrmo.html
Please advise,
Dusty
Please advise,
Dusty
RE: What Brushless Motor & ESC TO Use?
These ESC are mainly for heli and airplanes and none of them will do it. Car ESC is very different because of the break and higher requirements. Exceed-rc will have brushless system for our electric line soon.
Andy
Andy
ORIGINAL: DustyDoug
Andy,
Please advise,
Dusty
Andy,
Please advise,
Dusty
redcatracing offers and inexpensive great brushless system:
http://www.redcatracing.com/itemdeta...brushlessmotor
http://www.clermontmotorsports.com/s...s-setup/Detail
here is a video of it in my redcat tornado epx, i put it in my tsumami truggy too:
http://youtube.com/watch?v=KywosfFnmV0
http://youtube.com/watch?v=bPT0rwsqSjY
Thanks for the info guy's. I decided to go with the Red Cat set up, you guys seem to have it together pretty well and the system is put together to work with my vehicle, I hope...
Again, what do the kv numbers represent in relation to torque vrs. speed?
What did I buy? How many kv is the Red Cat motor and how many amps can the ESC handle?
There is not a lot of info offered when ordering, I just want to know more about the brushless systems.
Hay Red Cat support, did my order ship? I ordered yesterday and am hoping to have my brushless set up Thursday (2nd day air), I'm leaving for a trip Friday afternoon and wanted to get a test run in before I go.
My Order ID: 86598
Dusty
My Order ID: 86598
Dusty
Do you use the stock AM Transmitter that comes with the Exceed RC Truck? If so let me know how that brushless system you are getting ends up working out for you.
ORIGINAL: DustyDoug
My Order ID: 86598
Dusty
My Order ID: 86598
Dusty
hey bro,
i will post the information on the brushless system on the next post here, i dont know about your order since i only do support here for redcat, it should ship within a day of your order though. You will be very happy with your purchase bro, i promise
B4732 Car Speed controller Spec Instructions
Features / Specifications:
1. The speed controller is specially designed to offer high power and high efficiency
combined with low weight and compact dimensions.
2. Automatic cut–off , auto neutral setting and auto detection of all types and number of cells.
3. Perfect design for direct drive applications. The motor will respond to throttle input & accelerate instantly. There is immediately cut-off motor power when the voltage drops. Move the throttle to the neutral position & then push throttle forwards, the car will run again. Repeat above actions until the voltage drops under its battery’s specific low cut-off volt, the motor will then be completely shut down.
4. Over temperature protection – Status LED1 lights in solid red and Motor will be intermittently turned off when the temperature reaches around 95°c. Optional vent fan is available for selection to enhance the ESC ventilation.
5. Fail safe mode – While detecting out any abnormal signal or signal fail between transmitter &
receiver for about 2 seconds, the controller will cut off the motor power automatically. Once the
Signal gets back to normal, the system will auto-turn on again.
6. Specifications
6.1 Input voltage : 7.2V ~ 12V DC Ni-Cd / Ni-Mh battery
6.2 Output : Max. 540w/60sec, 225A (at 25°c ) 150A (at 100°c ) under good ventilation
Support: A < 5000KV 540S(36X50) motor ( 1/10 car)
B < 4000KV 540S(36X50) motor (1/10 cross-country car )
C < 3500KV 540L(36X60) motor (1/10 big-wheel car)
6.3 BEC : 5V 1A
6.4 Mosfet (inner resistance): 0.0166mΩ
6.4 Weight : 90g (fan excluded )
6.5 Dimension : 45mmx50mmx27 mm
6.6 Exhaust fan: 5v DC, on/off being controlled by system power
Operating Instructions:
1. Install the ESC according to the diagram shown below, Switch on the transmitter, Switch on the ESC power
2. Lift the car with the 4 wheels un-touching. Adjust & make sure the throttle forward direction
coincides with the ESC forward direction.
3. Right after turn on the power of the ESC, it will denote a series sound indicating the ESC is starting work. It will
then auto-setting the throttle Neutral denoted by LED2 in which fast inter-flashing with yellow & red light. While
succeed in setting neutral, It will then denoted by another confirmation sound & the LED2 will slowly inter-flash
with yellow & red light. If it is failed setting neutral, there will be no any confirmation sound. Please re-do &
re-check the system again starting from step1 of this instruction. This ESC is applicable to the transmitter with
the setting of 1/2 throttle & 1/2 brake/reverse.
4. Slowly push the throttle trigger forwards, the LED2 will be slowly flashing in red light. The flashing speed should
be proportional to the extent of the throttle acceleration. At the full speed, the LED2 will be in solid red light. If the
throttle forward direction does not coincide with the ESC forward direction, the light color will be in yellow not red.
Change the throttle reversing switch of the transmitter will correct the non-coincidence problem.
5. Motor rotating direction - Slowly apply throttle to check if the motor is rotating in the correct direction you desired.
To reverse the direction of the motor, switch any two of the motor wire
connections. Note : Do not reverse the battery wire connections! Reversing the battery polarity will permanently damage the ESC.
6. 1stly, trial running starting with a small gear motor for 2~3 minutes, measure the temperatures of both Esc & motor. If both temperatures are close with each other, they are at good match. The gear ratio can then be properly adjusted to optimum according to the features of the courses. However, It’s very important to always keep both temperatures under 100 °c, while adjusting the gear ratio. Otherwise the demagnetization of the motor will
happen, the motor efficiency will drop dramatically & the temperature will also raise up very quickly. Most
battery power is now wasted on heat nothing on motor efficiency.
7. It’s ok to replace a higher gear ratio or a higher KV motor while the temperature of the ESC is under 80 °c. But it
should be done according to para 6 described, from small to bigger. Unless the kv value of the original motor is
very low enough, It should replace a motor with lower kv value when the input battery voltage is changed to a
higher level. The ESC will be burnt if the motor doesn’t be properly changed while input voltage is changed. See
example below on the current changed inside motor while input voltage is changed;
Input 7.2V, inner resitance 0.18Ω --- 40A (V/R=I 7.2/0.18=40)
Input11.1V inner resistance 0.18Ω --- 61.6A (V/R=I 11.1/0.18=61.6)
8. Driving forward
Pull throttle trigger forward, the car will be in hard start mode, with very fast initial start, none delay acceleration, using the
minimum time to reach the full speed from still. Perfectly respond to the signal of the instantly acceleration. The braking
will be actuated by reversing throttle direction while driving forwards. Interval or spot braking can always be
controlled perfectly while driving forwards except when the driving speed drops to certain low level or slip driving
happens, which will then reverse to drive backwards after reversing the throttle direction.
9. Driving backwards
By reversing the throttle direction when car is in still or very low speed forward driving, the car will be driving
backwards. The braking will be actuated by reversing throttle direction while driving backwards. By reversing
throttle direction during driving backwards, it will get only a brief braking action & then reverse to drive forwards
instantly. The speed of driving backwards will be responded proportionally to the throttle input.
10. Warning
- Once the battery pack is connected, handle the model with extreme care, make sure you are clear of all rotating
parts.
- Connect the battery pack just before drive and disconnect it immediately after termination.
- Always make sure you are connecting the ESC to a proper power source that has the correct voltage & polarity.
Incorrect voltages or reversed polarity will damage the ESC.
6. Specifications
6.3 BEC : 5V 1A
8. Driving forward
10. Warning
parts.
ON, CANADA
are the brushless setups from Exceed ready yet or in the near future. Andy had told me to wait it out a bit (2 months ago) and now it's getting warm so whats up?? If Exceed doesn't have the brushless setup soon, I'm getting RedCat's version... as I already have all of the documentation.
AB
AB
ORIGINAL: ehroof
ORIGINAL: DustyDoug
Andy,
Please advise,
Dusty
Andy,
Please advise,
Dusty
videos removed bro????
TX
Ya know the traxxas brushless sytem will work also and many other systems like the Team Associated systems as well as some of the novack systems.
We have the brushless system ready http://www.nitrorcx.com/ezrun-brushless-combo-set.html it's works under exceed-rc electric on-road car and off road buggy.
Andy
Andy
http://www.raidentech.com/nohisphspbre.html
this ESC will work on the truck but we do not have a right motor yet. Yes we are currently testing and will roll out a setup for the trucks.
Andy
Andy
