Repair help
Repair help
Is there some kind of tool to take that little pin out? I let my buddy do 1 lap with my RC and that fool crashed and hit the wall and smashed my rear tire and broke my rear dogbone & rear axle and ruptured my fuel line, that guy sure as h3ll can't drive. I have a 1/10 exceed infinity, the pin is keeping the rear axle together.
RE: Repair help
is it the pin next to the chassis or the one that holds the hub to the lower arm?
if it is the one next to the chassis there may be a e-clip on both ends or you need to take the bumper off and it will reviel the pin. if it is what holds the hub to the lower arm there is a grub screw on the bottom you need to take out then you push the pin out with a little screw driver or something. if it is neither of these take a pic of what you are talking about.
