I need repair help
I need repair help
I have a 1/10 scale nitro monster truck and I just replaced my main gear and I cant figure out if my brake pad is suppose to turn or what, and I cant remember exactly where my throttle linkage assembly go. If you have any suggestion it will be very helpfull.
OR
RE: I need repair help
Usually before I tear apart somethin new and unfamiliar I write notes in a journal and take pics with the digital camera. You can always fall back on the pics to view the old setup and use the notes in reverse as a building guide.
I will look and see if I have a pic of mine on my hard drive that shows the linkage clearly and post it for you. I have a Ultra On-road but the linkage is the same part and setup the same.
Thanks! That really helped but now my rear tires isn't moving but the front is, what could be the problem? Did I miss putting something in it's right spot.
