Exceed RC Support - Nitro Cars Discuss all Nitro Car Support for items purchased or will be purchasing at Exceed RC.
My car eats differential gears?
Old 08-15-2008, 04:45 PM
Frozenshade
Default My car eats differential gears?
I have ran my buggy through about 1.25 gallons of fuel and it has already destroyed 4 spur gears. I am trying to mesh it as good as I can and the spur gear is parallel to the center gear? What else can I do? I should not have to replace a center gear every 6 tanks.
Old 08-15-2008, 06:29 PM
cirec
Default RE: My car eats differential gears?
I have the same problem.Will Exceed ever make metal gears?
Old 08-15-2008, 06:59 PM
Frozenshade
http://www.nitrorcx.com/stmaget46.html
Could this gear fit?
Ok nevermind, it doesn't fit
Old 08-15-2008, 08:20 PM
Frozenshade
Just curious as well, is having the gear's teeth overlapping about halfway a good mesh? Seems to roll smoothly when I do that, but maybe it does need to be changed. Any suggestions?
Old 08-16-2008, 11:02 AM
chevyderek72
chevyderek72's Avatar
ok this is what i do to mesh. get some paper, just like notebook paper, or printer paper. notebook is thinner and printer is thicker. and cut thin strips the width of the spur gear. get all the screws mostly screwed on the engine. and put the paper between the spur and the cb, push them together, not smash but get them together. while holding tighten a couple screws on the bottom of the chassis. then get the screws snug and pull the paper out. it shouldnt tear, but should be all bent up from the mesh. i can find a pic after work of what it should look like. also get a screwdriver and put it on the spur gear on the left side of the tranny, to hold it in place (when everything is tight) and then move the cb, it should have a SLIGHT gap. very small. then roll your car and it should roll smoothly with no binding. the more you do it the easier it gets. goodluck
Old 08-17-2008, 07:16 PM
jp3372
can you make a tutorial please (with picture) I buy one buggy today and the only problem I saw on this beginner buggy its this one, it will be very apreciated
Old 10-14-2008, 09:38 PM
cormier21
i was wondering if i could get one machined if it would work on it?
Old 10-14-2008, 11:12 PM
chevyderek72
if you mesh it like i said you shouldnt have a problem, but it takes practice
Old 10-28-2008, 05:41 PM
SAVAGEJIM
SAVAGEJIM's Avatar
ORIGINAL: jp3372
Though this is a different RC, the method to mesh gears is exactly the same no matter what teh RC.
http://www.youtube.com/watch?v=PD4xoEYmkfE
