Exceed RC Forza
NJ
RE: Exceed RC Forza
There is a set screw on the tranny. When you turn it, in/out, it'll allow you to shift sooner/later. It's been a while since I've messed with a 2-speed so I'm not sure which way you need to turn it to adjust it. Becareful though, I've read that those Forza's are known for eating spur gears.
NJ
RE: Exceed RC Forza
Here you go killer. I just looked up this 2-speed "how to" video from the RedCat thread. It'll show yiou what you need to do to get your tranny to hit second gear sooner. But also remember that if you are running too rich that could have some effects on it not shifting. My father-in-law was having that problem on Sunday. Was running too rich and wouldn't kick in to second. Good luck. Joe
http://www.youtube.com/watch?v=IVQlJuZIaLQ
RE: Exceed RC Forza
Trail Gunner,
I also have a forza, and recently ran it for the first time. Mine also would not shift into second. Unfortunately it mangaed to munch a spur gear in about 10 minutes.
After removing the trans, and comparing it to the exploded view in the owners manual, it almost seems as if the female clutch (#12) is installed backwards.
NJ
RE: Exceed RC Forza
I wouldnt put it past Exceed to mad a dumb move like that. I'll tell you what though. Making it single speed only is a ton of fun. I myself dont have much room to run anything two speed so my Hurrican is great around here.
RE: Exceed RC Forza
Second gear shifting problem resolved.
The female clutch (#12) was definitely installed backwards. After replacing 1st gear and putting the female clutch in properly. The Forza is shifting fine!
