runs fine wont go???
ok this is really bugging me! i took my nitro truck out for a run and it started fine. it runs great and the motor screams when you floor it but it will not move an inch? i checked out the drive shafts and diffs its all fine whats wrong?
RE: runs fine wont go???
Did you check the little nut next to the arm on the throttle servo? Mine came loose from vibration even after break in. It's a number 1.5 hex i believe. Mine did the EXACT same thing and all it was, was that little nut fell to far towards the low end needle. Hope it helps.
NJ
My grub screw for the rear cup came loose a few times. Then I put some loc-tite on it and have been fine ever since. But when that screw came loose I had front wheel drive only and could tell right away what the problem was. Is yours doing that? Could also be the clutch spring around the clutch shoes. Let us know what you find.
