Demon-Outlaw mix = SLOTH
Reply
Old 06-15-2011, 07:28 AM
Team_Monkey
Team_Monkey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Demon-Outlaw mix = SLOTH
I like the Screaming Demons and Outlaw planes but decided to mix the two. I ended up with a 36" span delta that looks like an Outlaw but has the Demon thin airfoil and upright engine mounting. Not to mention I build with coroplast so things had to be adjusted for the material.
So why SLOTH? Screaming Little Outlaw THing
The spar is 8% thickness tapered 1/4" poplar with AL barstock center brace.
Elevon Servos are HS-475 with XL Dubro Arms. The servos are mounted to a 1/8" ply plates glued in the wing and a piece of PVC act as a zip tie backers on the outside.
Pushrods are 4-40 but my LHS was out of right angle locks so I just used some pushrod EZ connecters. This way they are not bearing any mechanical load.
Engine is a Webra Speed .36 with Macs .25-.32 pre-tuned header/pipe assembly. The header is just over 3" long which I understand to be about ideal for this engine. The prop was just there for CG. Both the engine and exhaust were ebay finds. It fires up easily with a chicken stick, has tons of compression and feels like new.
The 6oz tank sits right behind the AL spar brace, a small 6V battery sits under the hatch right behind the engine, on top of the throttle servo.
CG is 13" from the rudder line.
http://i30.photobucket.com/albums/c3...202011/633.jpg In Flight picture.
It really flies great. Slows down to a nice high alpha and then can rocket vertical until you stop it.
Launch is simple. WOT to clear it out and just let go. I was running an APC 8x8 at ~18,000 on the ground but switched to an APC 9x7 at ~16,800 on the ground. The 9x7 is a perfect match as others have said. Running 10% fuel and an OS #8 plug.
I had to reduce the throws and add more expo after the first few flights. Once I get used to it I can't wait to explore more of the slow flight agility. it still rolls like a drill now. LOL
Many-many thanks to folks who have have given me info around here, I couldn't be happier with it.
Team_Monkey is offline
Old 06-15-2011, 09:58 AM
MJD
MJD's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Demon-Outlaw mix = SLOTH
I haven't got around yet to designing a new version of the Demon with a big central fin/rudder like that, but believe me I've had it in mind for a while and have doodled it a few times..
Cool!
MJD
MJD is offline
Old 06-15-2011, 09:05 PM
cmircman
My Feedback: (10)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
MJD if you made one of these i would have to buy at least a couple of them. now i gotta get back down into the shop and finish my Demon.
cmircman is offline
Old 04-16-2013, 08:25 AM
Daytona955i
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Team_Monkey
I like the Screaming Demons and Outlaw planes but decided to mix the two. I ended up with a 36'' span delta that looks like an Outlaw but has the Demon thin airfoil and upright engine mounting...
Hi,
nice work
why not a horizontal engine solution?
for me It seems more aerodynamic than upright...
ciao
Marco
Daytona955i is offline
