Unexpected power gain
Reply
Old 08-07-2011, 04:36 PM
freakingfast
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Unexpected power gain
I had to do a bearing change on one of my OS 46 VXDF engines. This is a well used engine but just as strong as the day it was broken-in and this is the third change it's going on. This time I went with stainless/polymite retainer rear and steel/polymite front. I purchased them from Boca because they had what I needed for the rear bearing, the others didn't. Like always, the two seals were pulled from the rear bearing. Usually, I then pull one seal off the front bearing, this time I left both on. This is a rear intake engine, so there's no port in the crankshaft. On most engines there is a close running fit between the shaft and the housing to keep the case pressure in. On these engines the fit seem looser, so I opted to keep both seals on the front bearing.
I cant give you a new speed number, but other several guys said it was noticeably faster then before, so it wasn't just my imagination. This is about the twentieth flight on the new bearings.
freakingfast is offline
