I need a good spinner for 3mm shaft 2600kv motor
AZ
Hello , I am putting together my first tractor style speed plane and am in need of a good prop adapter and spinner 40mm range. The one that came with the airplane had like .007 runnout where prop fits. And the backplate runs out as well , so needless to say it vibrates about midrange throttle shakes pretty bad so I am not even gonna try to maiden it with this setup. Suggestions under the $50.00 range?? or just spend the money?
NM
RE: I need a good spinner for 3mm shaft 2600kv motor
you could get a Pro Spin PS38 38mm 1/8" (3.2mm), and a PC33 3mm collet for PS38 for your shaft
Think Maxx also has the same thing w/a 3mm replacement collett
