GP LITTLE TONI WITH DLE 20cc ???
Reply
Old 05-14-2012, 11:12 AM
CHAPA
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default GP LITTLE TONI WITH DLE 20cc ???
I HAVE A QUESTION FOR THIS CONVINATION DLE 20cc WITH GP LITTLE TONY.
HERE IN MTY. MEXICO ON MY FLYNG CLUB THEY ARE USING THIS PLANE WITH YS 110 AND 115 ENGINES AND THEY SIMS BERY GOOD AND FAST. MY QUESTION IS WITH THE DLE 20 IS GOING TO BE FASTER THAN THE YS 115 4S?.
PLANE: http://www3.towerhobbies.com/cgi-bin...&I=LXGGG9&P=ML
ENGINE: http://www3.towerhobbies.com/cgi-bin...&I=LXAEPW&P=ML
BY THE WAY MY INTENSION IS TO PUT A APC 14X12 PROP.
TANKS IN ADVANCE FOR YOUR OPINIONS
PD. SORRY FOR MY BAD ENGLISH
CHAPA is offline
Old 05-14-2012, 01:37 PM
jeffk464
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: GP LITTLE TONI WITH DLE 20cc ???
ORIGINAL: CHAPA
How does the weight compare to the YS 115 with extra battery and all? People use them in 60 sized warbirds but you are talking a thicker airfoil.
jeffk464 is offline
Old 05-14-2012, 08:15 PM
speedracerntrixie
My Feedback: (29)
speedracerntrixie's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I doubt it would be any faster. Take a look at the video, these are mostly YS 115 powered and are close to the same size and drag as the GP Toni
http://www.youtube.com/watch?v=ReMWdfYnLSI
speedracerntrixie is online now
Old 05-14-2012, 09:44 PM
CHAPA
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
WEIGHTS:
YS 115 = 730g
DLE 20 = 820g
A DIFERENCE OF 90g; HEVIER THE DLE 20
DLE WITH IGNITION AND EHXAUST
4.8 VOLT BATT. FOR IGNITION = 122g APROX
TOTAL DIFERENCE = 211g
YS 115 WITH 20% NITRO AND 14X12 PROP =9,600 RPM
DLE 20 WITH 14X12 PROP = ????? I DONT KNOW
CHAPA is offline
Old 05-14-2012, 09:50 PM
CHAPA
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
THIS IS STATIC TRUST
CHAPA is offline
Old 05-15-2012, 12:57 PM
jeffk464
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My guess is that adding half a pound of weight is going to make landing significantly more challenging.
jeffk464 is offline
Old 05-15-2012, 05:08 PM
airraptor
My Feedback: (66)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No the DLE will not be faster than the YS-115. the warbirds in that video will also be faster than the toni with the YS-115. The YS 115 is the second fastest engine for the Toni with first being the DF engines.
Extra weight on this plane will not add much to the landing of this plane as it is very easy plane to fly and land. If you want faster and run a GAS engine then you need to run a SSYA 30cc engine as has a higher rpm power over the DLE 30. the SSYA should spin 15x14 APC around 9,000 or so. side mount it so the cheek cowl is helping to reduce the drag. seal off the other cheek cowl so no air gets in. take off the wheel pants and add race wheels of flying off paved runway. i would think 125-130 would be good with it.
airraptor is offline
Old 05-15-2012, 05:38 PM
C_Roundy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Chapa, I ran some calculations and here are the results. Extrapolating from the known fact that the DLE 20 does turn an APC Sport 16"x7" at about 9000 rpm, and the fact that an APC Sport 14"x12" is very close to the same engine load as the 16"x7" by my calculations, the 14"x12" will of course turn right around 9000 rpm too. The DLE 20 calculates to about 2.4 HP to turn either of those props at that rpm.
Whereas the YS 115 develops about 3.0 HP on low nitro fuel (and quite a bit more HP on high nitro), and therefore will turn the same 14"x12" prop somewhere around 9700 rpm on low nitro.
On high nitro the YS 115 develops about 3.8 HP, and will turn the 14"x12" prop somewhere around 10,500 rpm.
Basically, we are talking about a 2.4 HP engine verses a 3.0 to 3.8 HP engine. Also, remember that when your running big pitch propellers, a small rpm difference makes a big speed difference.......
Whichever you install, enjoy the Lil' Tony!
Chuck Roundy
C_Roundy is offline
Old 10-16-2012, 01:28 PM
earanguren
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am looking to buy the little tony, can you guys confirm if possible to install the dle 20 engine into this plane's cowl?
earanguren is offline
Old 10-16-2012, 03:14 PM
sctholson
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: earanguren
Excellent combo... this engine works great with this plane. To be on the safe side I increased the size of the firewall. There is some cutaway required of the cowling, but that didn't bother me.
sctholson is offline
Old 10-16-2012, 04:51 PM
earanguren
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for your valuable input, could you share some pictures?
Thanks again
Euro
Old 10-16-2012, 04:58 PM
sctholson
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'll be flying it tomorrow, I grab a few images then, a few with the cowling off and on.
Old 10-16-2012, 05:05 PM
earanguren
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Much appretiated.
Happy flyings tomorrow!
Old 10-17-2012, 03:53 PM
sctholson
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
As requested,
Notice the additional firewall is glued and screwed to the original. I don't know if you can make out the additional fiberglass, but I added it to the nose of the airplane as the airplane was in a crash prior to addition of this new and larger engine. Not sure it's needed for a brand new install.
ID:	1812220   Click image for larger version
ID:	1812221   Click image for larger version
Old 10-17-2012, 03:55 PM
sctholson
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
And a few more to round out the views.
ID:	1812223   Click image for larger version
ID:	1812224   Click image for larger version
Old 10-17-2012, 04:01 PM
earanguren
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sctholson
Many thanks, I picked up my little Toni today, those pictures are very very valuable for me.
Thanks again
Euro
Old 11-27-2012, 07:59 PM
mikes68charger
My Feedback: (33)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I put a DLE30 in mine. It was given to me and I had a 30 laying araround
I added carbon fiber toe to the i side and ouside the fire wall to keep the fire wall in.
No Led needed. Use a EBC for the ignition off the 2000 6.6 life that powered servos
Put the life way in the back of the tail
I used a APC 15x14 it was crazy fast and fun. It landing like any others Little speed bird.
I lost it after my 8th flight Hit a tree at WOT on a low pass
mikes68charger is offline
