jett 50 muffler
Reply
Old 10-13-2012, 01:21 PM
kork
My Feedback: (65)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default jett 50 muffler
i just got a new jett 50 and broke it in today with the supplied aluminum muffler gasket, it was spitting fuel out it. I am going to use hi temp form a gasket but can i get rid of the gasket when i add the sealant?
the engine is in a dc f-20 and holy cow what 17,000 rpm's sounds like!
jason
kork is offline
Old 10-13-2012, 04:00 PM
NoOneFlysAtMyClub
My Feedback: (32)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: jett 50 muffler
Just clean both mounting surfaces with alcohol first.
No need for the gasket.
Let dry overnight.
NoOneFlysAtMyClub is offline
Old 10-14-2012, 05:43 AM
Crazy4Flight
My Feedback: (540)
Crazy4Flight's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have used 5 minute epoxie for a gasket.
Crazy4Flight is offline
Old 10-14-2012, 11:03 AM
scoeroo
My Feedback: (9)
scoeroo's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I would draw file the mating faces to ensure they are flat, chalk the file so the alloy does not ball up and gall the face - alloy is a very soft material, and when using fine files it has a tendency to roll or ball up.
I do this on all my JETT engines, and any other engine for that matter ....... no issues
scoeroo is offline
Old 10-14-2012, 11:58 AM
kork
My Feedback: (65)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks guys, cant wait to maiden the bird, will look for leaks then
jason
kork is offline
Old 10-15-2012, 06:59 AM
daven
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
quite often the fuel is coming out of the front bearing and not the muffler or carb. It can be alittle messy.
daven is offline
Old 10-16-2012, 01:18 PM
lfinney
My Feedback: (44)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
most of the fuel coming out of my jetts is from reversion at the carb....
lfinney is offline
Old 10-19-2012, 09:23 AM
bob27s
My Feedback: (19)
bob27s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: daven
Dave has this right.
Especially on the muffler
If you see raw fuel on the muffler or carb body, its coming from the front bearing. Nothing to be concerned about, that is very normal.
If you find you have an exhuast leak... make sure you have the muffler clean and the surfaces clean. If they get buggered up then they will leak, but they will leak exhaust and that is easier to see. Sometimes I have used two gaskets on older engines.
Also... just of note after you run the engine, give it a few minutes to cool off, and check the muffler and cyclinder head bolts. Worth while if it is a new engine.
Bob
bob27s is offline
