GP F-4 Phantom
Reply
Old 09-12-2003, 12:57 PM
Bucshot
My Feedback: (16)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default GP F-4 Phantom
Great Planes has just re-released the F4 Phantom. I just got notified that mine shipped today! Any suggestions on a really hot engine that will fit this plane? I know Jett makes a load of really hot engines but you also need a load of money. Any other?
Thx
Bucshot is offline
Old 09-12-2003, 02:48 PM
Razor-RCU
My Feedback: (50)
Razor-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: GP F-4 Phantom
The only way to make it a great performer is with a Jett-90 or a OS-91VRDF engine- both are kinda expensive...
I read some folks have use an OS-91FX with decent results*
Great looking plane!
james
Razor-RCU is offline
Old 09-12-2003, 03:26 PM
Bucshot
My Feedback: (16)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wow, what's the deal? Is it the weight of the plane that makes it a dog? I was hoping an average 90 would work since it's a 60 size plane. I knew the Jett would be the answer but it is a little out of my budget.
Bucshot is offline
Old 09-12-2003, 03:27 PM
SJN
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Im finishing up my UK aerotek f-4. Its about the same size as the GP one. Ive bought a webra 91 P5 acro for mine. Im using the recomende prop of 14x12 to start out with. I hope it flys well.
SJN is offline
Old 09-12-2003, 03:32 PM
Bucshot
My Feedback: (16)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Very nicely done! I really like the tailpipe detail.
Bucshot is offline
Old 09-12-2003, 03:39 PM
SJN
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks, Im proud of it too :-)
It was so easy to do you wouldn`t believe it :-)
some aluminium tape, and a....ehhh..lead stick pencil....or whatever you call it to push in the rivets :-)
SJ.
SJN is offline
Old 09-14-2003, 08:34 AM
LUDS96
My Feedback: (22)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I saw one once that the person used an engine with rear exaust and ran the exhaust out the engine outlets! I'm going to put a super tiger 90 in mine with a pipe under the plane! Should look like a belly tank I have not looked at the plans in awhile but I also thought of turning the engine a little to get the pipe in the middle! I have two of these original kit's bought a second one when they discontinued it also I have a wing kit! Who knew I'm Glad to see it back! I'm a Vet from Nam and it's our bird!!!!!!!!!!!
LUDS96 is offline
Old 09-14-2003, 10:57 AM
SJN
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
heh yeah, the british colors are a bit dull too look at.
I would rather have painted it in US colors, as they look much cooler. But the markings in the kit are for the British Phantom K model, so i settled for that scheme.
SJ.
SJN is offline
Old 10-01-2003, 11:35 AM
3DEEP
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Does anyone know if this is a repro of the same kit? were there any changes made? I heard about some fitting problems with the ABS parts on the original run.
3DEEP is offline
Old 10-02-2003, 09:05 PM
SAPropbuster
SAPropbuster's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have the GP F-4 from the original run...
ST 90 for power...not what I'd call a barn-burner, though....
Flys nice, but not as quick as I have seen a F-14 w/ST 75 & tuned pipe...
Maybe if I add a pipe......................
SAPropbuster is offline
Old 10-03-2003, 08:14 AM
Bucshot
My Feedback: (16)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just got the Phantom kit. It is a re-release of the original with some changes. There is a label on the outside of the box that says "now with flaperon option." I also had heard about the fit problems with the ABS, but the review I read said they fixed that.
If I put a ST90 with a pipe, Perry pump, and retracts, do you think it would come close to a Patriot in performance?
Bucshot is offline
Old 10-03-2003, 10:58 AM
Razor-RCU
My Feedback: (50)
Razor-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What will be the "all up weight?" and what RPM's can you get from that combo?
Nice looking plane, that is-
Old 10-08-2003, 10:39 PM
CAPMDON
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I TALKED TO THE DESIGNER OF KIT AT SUPERMAN THIS PAST WEEKEND
THE REVISIONS MADE ARE IN THE ABS PLASTIC SIDE PANELS WHICH WERE
LENGTHENED A 1/4". MET HIM WHILE WE WERE ADMIRING A TURBINE CONVERSION
OF THE KIT.
CAPMDON is offline
Old 10-09-2003, 05:54 AM
Strykaas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
SJN, have u already made your Webra scream ? Is it broken in ?
Strykaas is offline
Old 10-09-2003, 09:29 AM
SJN
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Stykaas.
MY Phantom is a dog!!!! a slow dog...
The engine seems to perform well, but the drag on this aircraft is MASSIVE!
It will never fly as I would like it too :-(
I have tried 11 diferent size propellers, and have not come further :-(
from 11x11 props to 14x12. It realy needs the 14" prop for the pulling power. The engine realy performs well on the 11x11....if only it had weighed 2kg`s less ,and much more aerodynamicly clean.
Just too bad.... Speed realy bleeds off when doing fairly tight turns, and it drops like a rock when power is cut. It does some realy neat nose high landings. It comes in to land quite fast. And it need lots of elevator. Flaring out just before touchdown eats up the whole 1" of elevator movement. 1" on a fill flying stab is a lot!
I even opened up the intakes and exhaust to let air pass through the fuselage. The manual said it would increase speed.....I could not see the difference :-(
The plane weighs 4,6kg`s about 10 lb`s
SJ.
ID:	66523   Click image for larger version
ID:	66524   Click image for larger version
ID:	66525   Click image for larger version
SJN is offline
Old 10-09-2003, 10:09 AM
CAPMDON
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
lANDINGS DO LOOK GOOD WITH THE
F4. This one uses a OS91fx flies ok. Anything
less and it won't get off the ground
ID:	66531   Click image for larger version
CAPMDON is offline
Old 10-09-2003, 02:33 PM
Goinstraightup
My Feedback: (26)
Goinstraightup's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A guy in our club has one with the .91FX in it. He says it's a lead sled. He also says the .91 is barely enough.
Goinstraightup is offline
Old 10-10-2003, 08:58 AM
Bucshot
My Feedback: (16)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
All this lead sled talk is making me nervous! Maybe I should just dump the kit?!
mmmmm? How do I take a couple of pounds out? Think if you ditch the plastic parts and fab those parts out of balsa it would come out lighter?
Bucshot is offline
Old 10-10-2003, 12:02 PM
SJN
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
For its size, mine doesn`t weigh that much.......its more how bulky the airframe is.
I dont know about the GP kit, but my wings are REALY thick. That realy takes a toll on my model.
SJ.
SJN is offline
Old 10-10-2003, 05:49 PM
Strykaas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
that gives u easy landings !!
Strykaas is offline
Old 10-10-2003, 08:23 PM
Cyclic Hardover
Cyclic Hardover's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
[quote]ORIGINAL: Bucshot
Well its sort of true. Not a bad plane, just bad engine combinations. I have seen this plane and the GP F-15 and F-14 flying with St 90s and the owners have been very disappointed. I'm a speed man. Now i am not sure where your at or what you fly but it sounds like you want some sort of a sportscale prop jet. Find yourself a Direct Connection F-20. Throw a Jett.50 up fron and you have 125mph at altitude and 140mph around sea level. Otherwise with the F-4, F15and F14, your going to need no less than a Jett.90 and yourgoing to pay for it. Mine was around $350.
Cyclic Hardover is offline
